Question about Magimix Food Processors
Need to buy a new spindle cover for my magimix 5200. Where can I buy a new one. Having problems finding one.
    Top Expert:
  • Magimix Master
  • 55,370 Answers
Fixya is unable to suggest spindle cover sources.
Posted on Feb 22, 2018
2 Suggested Answers
rab-doo
SOURCE: The center spindle on my Magimix 5150 is stripped
Just researching the same problem. Apparently your can find the spare parts here:
http://www.magimix-spares.co.uk/Magimix-5200,-5100-spindle-cover-white,-Nylon-driveshaft-/product/104991/104991/
The old one is has push fit on an inner spindle and apparently can be prized off from outside without dismantling the machine. See the link below for further details.:
http://www.howtomendit.com/answers.php?id=47005
Posted on Mar 30, 2010
Lance Hill
  • 1739 Answers
SOURCE: magimix 5200
I believe the manual you are looking for can be downloaded from the following link:
http://www.magimix.com/upload/notice_d_utilisation/coffret/mash_and_puree_kit_instructions.pdf
Posted on May 01, 2012
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
How do I change the Nylon Driveshaft on my Magimix 4200?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and support the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 26, 2014 | Magimix C.s.4200 xl chrome mat - Mixeur...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
The center spindle on my Magimix 5150 is stripped and needs to be replaced. Any idea if this is a do-it-yourself project if I can buy the part or should I send it out to be repaired?
Oct 08, 2009 | Magimix 5150 Food Processor
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Dough hook stuck
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Sep 05, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Food Processors Logo
285 people viewed this question
Top Magimix Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Andrew Taylor
Andrew Taylor
Ruth summersides
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
