Question about Champion Garden
Locating a fuel tank for a champion r484tr lawn mower
Posted by Anthony Jones on
Terry
  • Champion Master
  • 11,377 Answers
You can search on eBay and other for sale web sites for it:
FUEL TANK FOR TROJAN R484TR LAWNMOWER eBay
Posted on Feb 22, 2018
Tom Chichester
    Top Expert:
  • Champion Master
  • 55,953 Answers
Fixya is unable to identify sources of fuel tanks.
1 Related Answer
mikehowy
Michael howard
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Can you use a champion spark plug rdj7y in 6.5 silver series lawn boy mower
Anthony you can use any kind of spark plug brand as long as its the same size. Sometimes they have a longer sparking element and this will catch on the piston. Just be careful.
Sep 10, 2013 | Champion International Lawn Mower Champion...
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Oil in my Champion lawnmower is emulsified. How can I drain the oil tank?
You can add a solvent like Diesel Fuel to it (engine) and pull the starter cord or starter to move it around...it will begin to break up the mess possibly.. You can also add Gunk Car Engine Cleaner too, to the engine oil, not the fuel.....A regular mower only holds about 20-21 oz of oil so be forewarned...
This is an interesting situation...is it even worth demulsifying?
Jun 04, 2010 | Garden
Champion petrol mower ran low on fuel - was
I suspect that there may have been dirt at the bottom of the tank or possibly water. Try changing the fuel filter but first clean the tank and refill with clean petrol
Oct 12, 2009 | Champion Jockstrap and Abdominal Supporter
My riding lawn mower won't start. New battery (cables & connections are clean), new filter, plug, rebuilt carb. It's getting spark but won't start? I cleaned the magneto and flywheel. Any other ideas?
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Jul 23, 2009 | Champion International Champion& Small...
Briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Jul 01, 2009 | Champion International Champion& Small...
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Champion Garden Experts
Lawrence Oravetz
Vernon Taylor
john h
Are you a Champion Garden Expert? Answer questions, earn points and help others
