Question about Andis Health & Beauty
I have a pair of Andis speed masters from the Pivot Pro combo I bought. I am an side barber so I well care for all of my clippers and trimmers. Anyways I went to turn them on and I slid the power switch on the clippers up and NOTHING!!!! I have tried many different outlets and still no power to the clippers? What can I do to fix this problem?
Posted by greg adkins on
5 Related Answers
Anonymous
  • 304 Answers
SOURCE: barber clipper blades
Soak them in motor oil the use 400 grit wet sandpaper (The black kind available at the hardware store) and lightly sand off the rust. They will be good as new when you are done.
George
Posted on Jul 25, 2008
Anonymous
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Anonymous
  • 61 Answers
SOURCE: loud andis master clipper
adjust power screw in one quarter turn
Posted on Jan 26, 2009
Anonymous
SOURCE: andis master clippers
Yeah bro.....just take off the top blade off the slider. Then you will see four screws on the slider, just tighten up each screw. The tighter you want the leveler, the harder you screw, be careful because they are easy to strip....that it, good as new....
Posted on Jul 11, 2009
philschneide
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
I need to take apart my andis master clipper to see what part i need to order i need the manual take apart the clipper
Stop, Their no manual on how to take your Andis Master apart. The Andis Master has small parts that you can lose. The adjustment on this clipper are not easy to do. I
Feb 11, 2011 | Andis Master 01557 Hair Trimmer
How do you get the noise out of an Andis Master after using the adjustment screw on the outside.
you have to adjust the screw on the side of the clipper with the regular flat screwdriver, just turn clockwise until the clipper gets quiet
Jul 29, 2010 | Andis Improved Master Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
HOW DO FIX MY MASTER ANDIS THEY ARE LOUD
Turn the clipper on and with a screwdriver turn the screw on the side all the way clockwise. Next slowly turn the screw back the opposite direction until the clippers are running at a normal sound level. If this does not work you will need to send the unit in for an internal adjustment. Please call the Andis customer service department at 1-800-558-9441 for further instruction.
Thank you for choosing Andis.
Sep 13, 2008 | Andis 01690 Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
Dec 01, 2007 | Andis Outliner II Hair Trimmer
Health & Beauty Logo
35 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
