Question about NorStar Lands Phones
Norstar m7208 only rings for a split second then goes right to voice mail box. Display says Forward>235
Posted by Jaime Holmes on
5 Related Answers
Anonymous
SOURCE: How many rings before call goes to voive mail
I have contacted Verizon tech support for this issue. They say it depends on where you are (what towers are responding to your incoming call) and can not be changed. I told them that Cingular could entend the ring time, not number of rings. The rude customer-no-service person told me "well, you need to go to Cingular-now AT&T". We will see what type of response I get from the letter I wrote to the President of Verizon.
Posted on Sep 20, 2008
blz131356
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
Anonymous
SOURCE: Doesnt ring
My BT Meridian compact does not ring after it powered down in a thunder storm. The lines flash and can be answered as normal just no ringing sound
Posted on Jun 16, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Sep 21, 2009
Anonymous
  • 30 Answers
SOURCE: all my calls are going straight to voice mail. my
check your call barring option, you may have mistakenly barred your incoming calls.
Posted on Oct 01, 2009
Display Message
This only shows on the operator extension. It is there to notify you that a Night or Evening or some other service is turned on. You can press the LIST soft key to find out which service is in effect. You can cancel the service, but then you also cancel the purpose of the service like night ringing or directing some lines straight to voice mail. Feature #871 will cancel ringing service, #872 will cancel restrictions service, and #873 will cancel routing services.
Jun 11, 2013 | NorStar M7208 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Nortel T3716E send calls to voicemail HELP!
Sounds like the call forward no answer isn;t set up on your extension. The first thing to do is to find out what the voice mail pilot number is. That's done by pressing feature 982. The display should say "set:xxx". The set number provided is the voicemail pilot number. Next you'll need to enter system programming. Programming is done on 7310, 7324 and 7316 type sets. Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change call forward no answer on.
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say foward no answer.
press theshow key (top right arrow)..
The display should say none. Press the chng key and enter in the voice mail pilot number. press the show key again (top right arrow) To review the rings til forward. Press the chng key if you wish to change the ammount of rings til answered. Press the release key when finished
Jun 23, 2010 | NorStar T7316E Corded Phone
Toggling between greeting 1 and greeting 2
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Mar 11, 2010 | NorStar M7310 Corded Phone
Same issue
Go into programming and forward your phone to ext 23 and then change number of rings
Sep 28, 2009 | NorStar T7208 Corded Phone
Sep 21, 2009 | NorStar M7208 Corded Phone
How to Check Voicemail Remotely?
call your phone and once the voice mail picks up hit rhe pound symbol you will have to look up what your phones default voice mail code is but after that you can set a code and check you voicemail using any phone
Jan 09, 2009 | NorStar M7208 Corded Phone
Where can i find instructions for using features Norstar M7031
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 08, 2008 | NorStar M7310 Corded Phone
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 02, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
