Question about Moen Plumbing
Moen 87786 Kitchen Faucet, seized and now Broken cartridge retainer ring/nut removal?
Moen 87786 faucet, 1224 cartridge, the fiber retainer ring was seized, soaked with calcium remover then with penetrant and then, using retainer removal tool, ears broke off cartridge retainer nut/ring.
  • Anonymous Feb 21, 2018
    Moen makes several faucets that use the 1224 cartridge and different means of securing the cartridge. Some use a clip, others use a brass collar nut, but the one for my faucet is an internal fiber/plastic retainer nut. This type definitely has a threaded cartridge retainer ring. Moen makes a removal tool that looks like a metal tube with a notched engage the retainer nut (Moen P/N: 179120). Once the ears on the retainer ring are broken, other means become nevessary to extract it. Moen calls it an "embedded cartridge nut". Some have recommended heat sometimes to the point of melting the retainer. Others have removed it by drilling the plastic nut in several places and pulling out the broken pieces.
Bill Boyd
    Top Expert:
  • Moen Master
  • 53,816 Answers
Get in a plumber to remove the unit and have anew unit installed
Posted on Feb 21, 2018
  • Bill Boyd Feb 21, 2018
    you may not like the answer but that is what you will have to do in the end --replace the unit
2 Related Answers
Anonymous
SOURCE: Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Posted on Sep 15, 2009
SOURCE: i have a kitchen single lever moen faucet and the cartridge wont
- I have a single lever Moen Kitchen Faucet and it's leaking around the base on top of the sink what could it be
Posted on Apr 19, 2016
How is the cartridge removed on the faucet?
How To Repair Cartridge Sink Faucets at The Home Depot
www.homedepot.com/.../project_guide_repairing_cartri...
The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
Dec 03, 2015 | Plumbing
Cannot pull out the cartridge. it appears to be moen part number 1224.
The Moen #1224 cartridge does NOT always come out easily! Sometimes the retaining nut (Moen part #14986) is jammed from factory installation and can even break on removal. Try soaking its threads with some Singer sewing machine oil overnight and then pouring a little boiling water on the nut to expand it at the same time as you start to turn it counter-clockwise with pliers.
Next you may find the cartridge almost impossible to pull out! You do not need a special tool. Just purchase a stainless #8 x 32 machine bolt and screw it well down into the threaded hole on the top of the cartridge. Then use a piece of wood like a scrap of 2 x 4 as a pivot point and put the vee of a pry bar under the head of the screw. Make sure you are levering upwards exactly vertical and you should be able to pop the cartridge out. Clean the hole and grease it with a little Vaseline before pushing in the new cartridge. See photos.
Mar 16, 2015 | Moen Kitchen Faucet W/Double Knob Handle,...
How do i fix my leaky moen bathroom faucet?
May 21, 2014 | Plumbing
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
Replaced moen teo handle cartridge 1224 now faucet
the lines the cartage attaches to will have seals or teflon tap. if the seal has a small nick, it will leak. Or if the tape was applied in the incorrect dircection or was cut it could also creat a leak
Jul 19, 2010 | Moen & Replacement Cartridge
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Replacing Moen O kitchen faucet O ring
if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
Oct 19, 2009 | Moen & Replacement Cartridge
Plumbing Logo
559 people viewed this question
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
