Hi Nar poudel, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What is your question? If unable at this time, you can click on the menu to delete your message if necessary, and enter a new message later when you find the name of the manufacturer, model name and number, and exactly what is wrong.Hi Nar poudel, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Yes and worse, it can short out the inverter with both a low voltage hi frequency current which can cause the inverter to catch fire or a hi voltage low frequency current which will have the same effect.
STOP USING THE TRANSFORMER
It is a FIRE HAZARD when used with an inverter. Buy a new one.
As for using it with a Battery it could cause the battery to EXPLODE !
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
hi you have two resens for this the first is your alternator is defective and your inverter can't not read the good isotopefrequencies and the deep you lisent it's wrong isotope
the other one, you have two transistor attach to a cooler, these are scrap, this is those hoo create the isotope (hz) and hosting high ac current
