PC must be internet connected
the PC must run W7 or newer.Some newer mice are w10/11.
NO OS told by you, your PC L655 (2010 made , windows 7 ,NIB)
no mouse model told off bottom of mouse
mouse battery good
mouse nano usb receiver connected to USB port L655 (must)
mouse power switch on
mouse paired (connect)
there is no ONN SUPPORT site it is walmart junk so....ask them.
WM is clueless.
this mouse (all at WM) use MS, Microsoft Pnp Plug and play t
work
therefore no support page or CD exists. at all.
PC must be internet connected and working on WWW
the real problem as many ONN devices at walfart (USB things for sure)
do not run things older than
OCT 2009 (W7 BIRTH DAY)
and some are 2015 and newer PC only w10
the try hard to be not clear in this.
they try hard to assume whole would is w10 up. (or new mac)
BEST IS AVOID THINGS (USB) FROM WALMART
OR TAKE IT BACK RETURNED AS 1/2 DO IN THE LONG LINE.
SOURCE: Microsoft Wireless Notebook Optical Mouse 1023 Need Driver
i wanna know about Microsoft
Wireless Notebook Mouse model 1023, is there any driver software need
to that mouse, please tell me sir
need a driver, mouse works but USB doesn't light up
SOURCE: how can i download mouse driver
Check these two links Bioticaindia MassDrives There may be some issues with that mouse. Previously there were issues like reconnection needed if mouse was idle for more than 25 minutes
SOURCE: I cant find drivers for
Here is your drivers....... click here
Please rate me, if you are happy
SOURCE: onn wireless mouse driver error will not install
Uninstall if there was an earlier installation done. It is best to make sure that the wireless mouse is working on another PC so as to confirm if there is any fault on the OS having a corrupt program. Also if files are missing due to a virus within then it will not install properly.
Once confirmed, try and restore the PC to an earlier set date. Now install and then connect the mouse. if there is no response then there is fault in the OS. Also check the USB ports seperately to be working
