No steam and no hot water from dispenser as well. Also, when turned off, the gauge on left side with 0, 5, 10, and 15 is stuck around 5.
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
SOURCE: KPES100PM Espresso Machine - will not make espresso
While I am familiar with Kitchenaid espresso makers, I am not familiar with this problem. I would suggest calling Kitchenaid Customer Service, as you will have options under your Pro Line warranty. Their toll-free telephone number is:
1.800.541.6390.
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
SOURCE: The espresso side of the
The clue here is that the problem involves the hot wate and the single or double espressos. These three functions require accurate water measurements and they are programmable. It appears that the flow meter is not sending the correct information to the control unit. This could happen if you have blockages or if the flow meter is not working anymore. Most likely you need a new flow meter which only costs about $20 and should not be too difficult to replace. It is located between the water tank and the pump.
SOURCE: Have had Solis SL70 espresso machine for 2.5
Hi
You valve is out of adjustment. Everybody thinks that the valves opens to allow water or steam through. It doesn't. When you twist the valve it pushes a needle to open to allow water/steam through. When you close the valve it allows the needle to seat, but if you keep twisting the knob it gets out of adjustment. It just moves the valve farther from the needle.
First unplug the machine. Remove the water tank. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 Allen screw. Loosen this screw and the rotate the cam counter clockwise until it stops. Push it to the left as far as you can (it should touch the screw on the left), then tighten the allen screw. This is the proper adjustment. Reinstall the top. There is a grove in the top that the face fits into. Gently push the top back and the face will go with it. Then put the screw in the back and your done.
