Question about Alba Televison & Video
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If
that does not work, the unit must be disassembled, and lense cleaned
with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
SOURCE: my alba dvd player has stopped playing cd rw
Can it play other REGULAR discs?
if not - try cleaning the DVD head (there are special discs which you can buy).
Posted on Mar 05, 2009
SOURCE: Alba DVD player P500. Spins and then says no disc
change the motor disc spindle
Posted on Jul 22, 2009
SOURCE: alba portable dvd player is
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective. The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer. Thank you for using Fixya
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Posted on Sep 22, 2011
SOURCE: Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Posted on Jan 23, 2012
Testimonial: "Got some of these cables, need the adaptor... brilliant info Thanks a million....."
