Question about Simbans Tablets & eReaders
How do I delete something on a Simbans Tango tablet?
Posted by Shirley Nicholas on
I hold my power button and volume botton but my simbans tablet wont turn on even when charged
Sounds like the power button switch has given up on you. With a lot of care and time, you can fix this yourself for a few dollars if you buy the part and tools on eBay, or you can just take it to a repair shop.
Jun 03, 2018 | Simbans Tablets & eReaders
I have a simbans tango tablet gifted at xmas and the sound is not working.I can hear with headphones. What to do? I'm in Canada.
swipe down from the top and check the settings in "audio profiles" See if the speaker is muted.
Jan 25, 2018 | Simbans Tablets & eReaders
How can I download a driver from Simbans so I can download and upload to my PC?
You just connect it with you USB cable and transfer using Windows Explorer. It will be shown as a Removable Drive.
No drivers or software exists. Brand leader is iPad, which does have some capabilities via iTunes.
May 05, 2016 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
User manual simbans ultimax 10'' tablet
Your manual is here.
Turn your device on and off To turn on your device, press and hold the power key.
To turn off your device, press and hold the power key, and then tap Power off?OK.
Manuals
Dec 29, 2015 | Simbans Tablets & eReaders
Need to reset simbans ultimax tablet pc due to space problems. get message of 'not enough storage to download app'. how do I do this?
To reset your tablet you need to go to setting then find backup & reset and when you are there you should click on factory reset
Aug 15, 2015 | Simbans Tablets & eReaders
When I want to install more apps says I have no more storage.yet I do .what's wrong Storage says available.
On your internal storage SD card there is an App partition. This is where all your apps are stored. Many devices have a small App partition like maybe 1 gigabyte. It doesn't take long to fill this up with additional apps.
Many Android devices display this App partition storage bar graph in Settings > Storage. It's usually the top horizontal bar graph. If it's all one color then it's full and it will perhaps say something like 1 gigabyte of 1 gibabyte used. The only way to get
more room to download new apps is to delete some of the old ones, or in some case a few of them might be able to be moved to the external SD card if your device has one in its slot.
May 21, 2015 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
How do I unlock my tablet/
Whats your tablet brand and model ? Do you want to unlock your tablet from carrier lock? If so, use unlock code . You can get it from any of the online vendors like SimpleUnlocking.com to unlock it .
Oct 25, 2014 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
Can't get my pattern to open tablet
As you probably realise you are entering the wrong pattern! You will have to wipe everything with a factory reset back to when new!
Oct 24, 2014 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
My battery wont re charge
Try a different charger, if this doesnt work you'll have to consider replacement or repair. Hope this helps, Graham
Oct 19, 2014 | Simbans TM S74B 7 Inch Tablet PC - Dual...
How to delete my recent call on tango ipad
Go to recent call log and remove the calls from there.
Jul 12, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
73 people viewed this question
Top Simbans Tablets & eReaders Experts
 Mikey
Mikey
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Simbans Tablet and eReader Expert? Answer questions, earn points and help others
