Question about Toshiba Office Equipment & Supplies
Toshiba E-studio 2500c, error code CE40 - Toshiba Office Equipment & Supplies
Posted by Nishan Jayakody on
kasun fernando
    Wolfpack:
    An expert that has 5 followers.
  • Toshiba Expert
  • 253 Answers
Image quality control test pattern abnormality
Posted on Mar 19, 2018
5 Related Answers
didi2005
  • 727 Answers
SOURCE: C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
Posted on Mar 09, 2009
didi2005
  • 727 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
patrick hopkins
  • 132 Answers
SOURCE: toshiba estudio 351c error code
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Posted on Apr 12, 2011
Anonymous
  • 60 Answers
SOURCE: Error code C970 on my
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
Posted on Jun 12, 2011
Ce40 error on toshiba 3040c - Toshiba e-Studio 3040c
CE40 is image related error, u need to check which pu giving the problem...
Jun 06, 2018 | Toshiba Office Equipment & Supplies
I have toshiba e-studio 2500c error code E030. No paper jam.
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 27, 2016 | Toshiba E-studio 2500c Color...
CAN YOU PLEASE GIVEN THE SOLUTION FOR ERROR IN ce40 code in estudio2050c
You must change black dev.unit lever clutch to fix CEB0
And you must change the belt that moves organic belt to fix CE40.
Aug 05, 2016 | Toshiba e-Studio 2050C Multifunction Color...
How do I remove error code ce60?
Error ce60 e-Studio 2820c - Fixya
www.fixya.com/support/t17213833-error_ce60_e_studio_2820
Mar 19, 2013 - So I put in the code 8 clear/stop so it will show the error code. No error code is popping up. The number 8 just stays on the screen, like nothing ...
Jan 27, 2015 | Toshiba E Studio 2330c 2500c 2820c Copier...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
CE40 is image related problem, u need to check which PU is giving the problem
Oct 24, 2012 | Toshiba e-Studio 3040c RADF Assembly OEM -...
Error code C970 on my toshiba e-studio 2500c. Sais call for maintanance...Can I clear this or fix this on my own?
Jun 08, 2011 | Toshiba e-Studio 350 Copier
Feb 04, 2009 | Toshiba E-Studio 161 Copier
Open Questions:
2,336 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
