I found two spool pins for the Babylock Espree EM1 listed here: https://www.sewingpartsonline.com/babylock-em1-sewing-machine-parts.aspx . The direct link for the extra twin needle spool pin is https://www.sewingpartsonline.com/spool-pin-130920021.aspx . (This fits several Babylock models.) The other spool pin is https://www.sewingpartsonline.com/horizontal-spool-pin-white-x58708051.aspx .
I hope this helps.
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
SOURCE: Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
SOURCE: need a manual for a baby lock serger model EA-605
You might take a look on ebay item 160362974035
