Washing Machines Logo
Question about Bosch Washing Machines
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Started showing a E01 and watched a youtube on removing the plastic piece under filter, nothing in around pump but he recommended to run a cycle in case something in pump. But cannot get the E01 code off to start a cycle
Posted by Sherman McCool on
Dan Peters
    New Friend:
  • 48 Answers
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
Posted on Apr 30, 2018
5 Related Answers
Anonymous
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
Anonymous
  • 478 Answers
SOURCE: Bosch SHV46C
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
Anonymous
  • 3614 Answers
SOURCE: bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
Posted on Jul 08, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: Cannot remove pump filter cover -Bosch Exxcel 1400
Before removing the filter have you drained the excess water with the drain hose to the left of the filter? The filter cap should turn around 1/4 to 1/2 turn so the best option is to close it again and then repeatedly try opening it with a little more force each time. The black plastic cage could affect the removal of the filter and once removed if it is damaged you may need to replace it. These are available via most domestic appliance spares stores or directly from Bosch. Once removed check for any black plastic debris in the filter housing and chamber.
Posted on Oct 23, 2009
Testimonial: "Very helpful response - thank you."
Anonymous
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
Bosch Dishwasher E01 Code
Two different ideas from Bosch, either control board or heater element, temperature thermistor. As it fails at the rinse stage where the water is hotter, I would check the latter, or just call for service and get it correctly diagnosed and fixed. If you want to try some things, check connections to the main control board and to the heating components.
https://www.google.com/search?q=Bosch+Dishwasher+E01+Code
Bosch SHE3AR75UC/08 E:01 After A Lightning Strike
Contact Bosch direct, we aren't they.
You need a service call and an engineer with a laptop.
Bosch dishwasher error code e 01 If a Bosch dishwasher displays the error code e01, it means the control panel is malfunctioning. ... If the dishwasher does not work at all or fails, the faulty control board is probably the case. It controls all the functions.
Bosch dishwasher error code e01
https://bosch-dishwasher-errors.com > bosch-dishwasher-e...
Search for:
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
1helpful
Started with E01 and E25
The E01 fault code means that the dishwasher has suffered a power module failure.
The programming of replacement power modules E01 up until E05 has been locked down by Bosch so in the event of an error code of this type it's recommended that you contact a Bosch approved dishwasher engineer.
2helpful
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at [email protected] and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
25helpful
1helpful
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Open Questions:
Top Bosch Washing Machines Experts
Marvin
Marvin
Steve
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
