Clock wise is to the right if facing knob.So counter clockwise is turning knob to left and a 180 degrees is half a revolution. Buy a protractor from an office supply store https://www.mathsisfun.com/geometry/protractor-using.html
and turn know to 15 degrees on the protractor.
or use a mobile phone app like https://play.google.com/store/apps/details?id=kr.sira.protractor&hl=en
https://itunes.apple.com/us/app/protractor-1-angle-converter/id331027151?mt=8
SOURCE: How do you get the
push in turn counterclockwise remember dont touch bulb with your fingers keep it clean,oil from your finger and dirt will reduce the life of the bulb.
SOURCE: 2001 mazda mpv radiator fan rotates clockwise or counterclockwise?
it should pull the air inward if its not reverse the the wires and it will reverse the direction of the fan
2.4L Engine Firing order: 1-3-4-2 Distributor rotation: Counterclockwise
3.0L Engines without DIS Firing order: 1-2-3-4-5-6 Distributor rotation: Counterclockwise
V8-318 and 360 EnginesEngine Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise:
V8-400 and 440 EnginesEngine Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Counterclockwise:
V8-383 and 44 EnginesEngine Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Counterclockwise:
