Question about Amazon Tablets & eReaders
How can i restart my amazon ilivePlatimum (iswfv387g)
Posted by Amy Barickman on
Anya General
    Sergeant:
  • 119 Answers
Hello Friend Restarting your device can resolve many issues. Just disconnect the power cord (from the back of the device or from the power outlet), and then plug it back in. You can also use your remote to restart your device. Press and hold the Select and Play/Pause buttons at the same time, for about five seconds.
For any help or support just visit us: www Kindle Com Support
Posted on May 24, 2018
What to do if your Kindle paperwhite is not turning on?
As long as it is charged.
Amazon.com Help: Restart Your Kindle E-Reader
www.amazon.com > help > customer > display
Restart Your Kindle E-Reader · Press and hold the power button until either a power dialog box appears or the screen goes blank. · Continue holding the power ...
How to restart your Kindle device in 3 simple steps - Business ...
www.businessinsider.com > ... > Tech Reference
Mar. 10, 2020 - You can easily restart your Kindle device if it freezes or stops ... You can restart your Kindle at any time by pressing and holding its power button for 40 ... to all Kindle models, so whether you have a Paperwhite, Oasis, or an ...
tip
How to reset the Amazon Kindle (useful when the unit is frozen)
Hi.
The Amazon Kindle is known for having several firmware issues, and it is not unusual seeing the unit freezing and not starting.
To start you can attempt doing a soft reset. To do a soft reset press and hold the <ALT>, <Shift>, and <R> keys simultaneously. The Kindle display should go blank for few seconds, and then restart.
If your Amazon kindle is still frozen, try resetting the unit to factory default settings with the hard reset procedure below. Procedure is different, depending on the Kindle model.
All you have to do to reset the Amazon Kindle 2 and Kindle DX is pressing and holding down the power button for about twenty seconds, then release the button and let the unit restart.
If instead you have the previous model, the amazon Kindle one, then you will need to open the back cover by pressing it and sliding it to the right with your finger, same as when you have to replace the batteries.
Behind the cover you will see the reset hole switch.
Push and hold a sharp pointed object, like a paper clip, or the tip of a pencil inside the hole button located under the battery cover.
Wait about ten seconds until the Kindle restarts and resets to default settings.
The last procedure and the picture below refer to Kindle one only. If you have kindle two, then please use the first procedure.
If the above does not fix the problem, then the unit is faulty. In that case contact Amazon to get support.
Regards.
How reset fire Amazon tablet not charging
if not charging reset is not going to solve it and if battery failure cant restart check charger and ports if good most likely battery failed
2answers
Kindle paperwhite won't respond to "Swipe to unlock Kindle. Seems frozen. What do I do to unfreeze it?
Restart Your Kindle Paperwhite. Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation). Press and hold the Power button for seven seconds until the Power dialogue box appears, and then tap Restart.
Amazon.co.uk Help: Quick Fix: Restart Your Kindle Paperwhite
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=201176080..
or go to this link might help you out... Kindle paperwhite won respond to Swipe to unlock Kindle Google Search
Kindle paperwhite keep freezing or won't let me swipe to change page
I always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
After charging overnight I only have a white screen when I switch it on
Try this suggestion rom Amazon:
Restart your Kindle Paperwhite
Why can't I get Alexa to sync through my home wifi connection?
Amazon.com Help: Can't Connect to Wi-Fi
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.Make sure your Internet connection is not down. Restart your router and modem to solve most Wi-Fi network issues. Move Amazon Echo closer to your router ...
Amazon.com Help: Pair Your Mobile Device with Amazon ...
I thought I deregistered it and gave it to my daughter but my name keeps showing up and it wont let her register under another name.
How to reset / restart your Kindle - YouTube
? 1:42
www.youtube.com/watch?v=XXj8PuYYY4Y
Feb 4, 2013 - Uploaded by Pieter De Waal How to reset / restart your Kindle. ... It won't reset or anything. .... Amazon Kindle 3 3G/GSM/WiFi 6" TEARDOWN - EEVblog #109 - Duration: ...
Can&#39;t get onto my amazon account, doesn't register password
clear your browser cache, restart browser. make sure your keyboard keys are working correctly, make sure caps lock is off
Tablets & eReaders Logo
Top Amazon Tablets & eReaders Experts
nexrad_chris
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
