Question about Power Computers & Internet
SOURCE: printer will not turn on
the UPS is unplugged from the power outlet but it is still connected to the modem
it is a lightning storm - and computer equipments & peripherals can only withstand very little amount of electricity
check your warranty status (warranty starts from the date of purchase) then call the vendor
Posted on Jan 04, 2008
SOURCE: hi,do I have to keep my ups plugged to a wall socke all the time?
hi,
the unit needs to be plugged in all the time. the unit is or should be fully automatic. higher priced units have a usb cord so you can check their status right on the computer, does your ups have a usb outlet? you might want to take it up to a computer store and buy a usb cable and then you can control your UPS with your computer. manually turning the UPS on and off shouldnt hurt anything.
good luck
jm
Posted on Aug 01, 2010
SOURCE: i have a rocketfish 1025
Well, first let address the lack of power usage from your router and cable modem. The router, depending on model, may only use less than 5 amps of of power, depending on the load it is using at any one time, the cable modem is using maybe 2 amps, at peak load, since the line is already powered from the cable company, there is no real load. Since the usage is much less than 1 watt, it would not register on your meter. The reason why unplugging your devices from the wall, for it to not provide backup power to all of the devices is the battery(ies) may not be providing enough juice to maintain the power required for ll of the devices plugged in. Also, UPS are generally not compatible with power strips and therefore do not tend to function properly with a devices powered on the strip. They generally won't complete the power connection due to the strip carrying a much higher load than the UPS can support. This should explain all of your power issues. If you require additional information, please do not hesitate to ask.
Posted on Aug 19, 2011
Feb 26, 2015 | APC Sua1500rm2u SmartUps Usb Serial Ups...
Aug 18, 2011 | Rocketfish RF-1025VA UPS System
Jun 03, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Aug 01, 2010 | APC (BE500U-WEB) (BE500UWEB) UPS System
Jan 09, 2010 | TriPro Power (POW-1000AS) UPS System
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
Mar 13, 2009 | APC Back-UPS Pro 650 UPS System
Jan 26, 2009 | Computers & Internet
Jun 25, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Dec 20, 2007 | Epson RX620 All-In-One InkJet Photo...
Jul 19, 2019 | Power Computers & Internet
23 people viewed this question
Hi K S Metzler, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
make and model of UPS ?
MyPC Cable ? what is it a 240 v power plug or 120v power plug ?
