SOURCE: OLDER ICOM RADIO ICBP5 AND A REGENCY U156B
Hi, The Icom radio models start with IC followed by numbers and then letter(s). The BP5 is the model of the battery pack. Pls post back. I'm not familiar with Regency U156B. However, there is a Regency RU156 which is a 16 channel UHF 25watt mobile radio which could either be crystal controlled or PLL diode matrix. Regency was reported sold to the BK Relm Company, which no longer supports older Regency Radio Equipment. There are a few sites on the Internet where you can get hold of a user's manual (some for a fee) like http://www.bearcat1.com/manuals.htm. Hope this be of some help/idea. Post back how thin gs turned up, the Icom model or should you need additional information. Good luck and kind regards.
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
SOURCE: How to program an Icom IC-R5 handheld scanner
to store a fcy press BAND to go to your fcy range ie 118.000 airband
dial your fcy ie 127.900(shanwick ocean area control) press and hold V/M for 1 sec, small numbers now blink, dial the memory slot you wish to store into ie 001 then press V/M again for 1sec and this will store 127.900 into mem slot 001. make a list:-
mem number / fcy / mode(am - fm) / station / bank
to prog a fcy into a "bank", press V/M for 1sec - blinking mem numbers - dial mem number ie 001(127.900) press MODE - "bank" flashes past-
-- -- -- -- 001 shows, turn dial to show A-00 this is the first "bank", pressing BAND scrolls through all the alpha "banks" - choose one.. ie A-00 (for airband..) press V/M this puts mem 001 into "bank" A mem slot 00, there are 100 slots in each letter 00 to 99. do this to any fcy you want to scan as a group.
to scan a bank press V/M - small numbers appear -
press BAND to scroll through any "banks" you have created ie A B C D etc (only banks with fcys in will display), press MODE -"bank"- press MODE again and you will start scanning just that "bank" of mem slots.
MODE starts and stops the scan... each letter holds 100 mem slots.. happy scanning!!!
ICOM AT-180 Automatic Antenna Tuner
The Icom AT-180 is a fully automatic tuner with 70 channel preset memories. It provides reliable matching of frequencies from 1.9 to 54 MHz. Please note it does not operate on 144/440 MHz bands. The matching impedance range is 16.7 - 150 ohms (HF band) and 20 - 125 ohms (50 MHz band). Tuning accuracy: Less than SWR 1.5:1.
This tuner requires about 8 watts (minimum) to activate and can handle up to 120 watts. The rear panel has SO-239 input and output. It operates on 13.8 VDC (less than 1.1 amps) drawn from the transceiver control cable. Size: 6-9/16 (W) x 2-5/17 (H) x 8-7/8 (D) inches 5.3 lbs. (167 x 59 x 225 mm 2.4 kg). The AT-180 includes the 13 pin ACC cable and a 38 inch PL-259 to PL-259 coaxial jumper cable.
Compatible with ICOM two-way radios:
IC-703
IC-703+
IC-706 MKII
IC-706 MKIIG
IC-718
IC-7000
IC-7100
IC-7200
IC-7300
IC-7410
IC-7600
IC-7700
IC-9100
