Question about American Standard Home
Can I use Epsom salts in an American standard jet corner bathtub with a heater without causing damage. Would it void warranty
Posted by Ronald Warner on
Andrew Taylor
    Top Expert:
  • American Sta... Master
  • 33,322 Answers
Safe Use of Epsom Salt in Jet Tubs ' Healthfully
https://healthfully.com > Health
Jul 27, 2017 - Salt baths help maintain muscle and joint tissue, and improve brain and nerve functioning. It's not surprising then that many people think of adding salt to their hot tubs. It's a great idea as long as you heed a few guidelines to keep the salt from interfering with the normal functioning of the jets.
How to Use Epsom Salt in a Jet Tub ' Healthfully
https://healthfully.com > Health Jul 27, 2017 - Epsom salt can ease muscle pain, reduce inflammation and flush toxins from your system. When combined with the therapeutic properties of a jet tub, Epsom salt are the perfect remedy for a sore or stressed body. Although it's safe to use Epsom salt in your Jacuzzi, you'll need to take precautions to ensure ...
epsom salt jet bath Google Search
Posted on Feb 18, 2018
5 Related Answers
SOURCE: The pop-up drain stopper on my American Standard bathtub no longer seals in the down position. Any suggestions? KG
Unscrew it (turn left/counterclockwise), thoroughly clean it, lubricate it with liquid dish soap, screw it back in. If it still doesn't work, best bet is to get a replacement.
If, when you remove it, you find the gasket around the bottom is torn, probably ought to replace it and forego the cleaning step.
Posted on May 10, 2009
snap101
snap101
  • 117 Answers
SOURCE: leaking noritz water heater
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech [email protected]
Posted on Jul 28, 2009
Alan
  • 80 Answers
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Posted on Mar 26, 2010
Anonymous
  • 76 Answers
SOURCE: can i safely use epsom salt in my jet tub?
epsome salts are only used for bath salts ,there is no harm.
Posted on Dec 30, 2010
Jace
SOURCE: I purchased an American Standard
The water in the tub needs to be higher than the jets!
Posted on Oct 05, 2012
Is Aveeno Colloidal Oatmeal Treatment safe for this American Standard Installed Whirlpool Bathtub?
Hi Virginia,
I've done some research on tubs with jets, and from what I've read I wouldn't put anything granular in the water.
The granules may damage your pump and also when the water stops some granules will be left in the pipes, where they will decompose and turn into.... well, I don't think it'll be nice.
Nov 24, 2015 | Whirlpool Home
Will epsom salts harm whirlpool
DO NOT use products with glycerine or oil in any Jacuzzi or whirlpool bath. It will harm the jets. Label oil or glycerine-containing gifts, "Not for Jacuzzi or whirlpool!"
If you need further help, reach me via phone at https://www.6ya.com/expert/sandra_f3927183d795a50a
May 03, 2012 | Kohler K-1110-AH-0 Purist whirlpool with...
I have a homedics foot bath with water jets and no instructions. Can I use epsom salts in the foot bath?
According to the manufacturer it is not recommended you use Epsom salt in this product as long term use can cause corrosion to the water jets. I hope this helps.
Jun 22, 2011 | Health & Beauty
My American Standard spa tub Williamsburg Elite Model 2425E has a couple of the eight jets failing to jet, the two on either side of the rear left corner.
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
Dec 31, 2010 | American Standard Home
Can i safely use epsom salt in my jet tub?
Dec 30, 2010 | Whirlpool 2 Person Corner Air Tub By...
Pushed button to turn on whirlpool - hear motor - jets don't work
if the motor just hummed then it is likely a bad motor. you will need to replace the pump at that point. Bathtub buttons like the one you have either works or they do not. there isn't any in between areas.
May 31, 2010 | American Standard Cadet Corner Bathtub -...
How to remove jets from american standard jetted tubs for routine maintenance
Jet trim usually unthread counter clockwise out of the wall fitting
Sep 21, 2009 | American Standard Home
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
Apr 28, 2009 | American Standard 2771.002.021 Cadet 5' x...
Home Logo
1,928 people viewed this question
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
