Question about Makita Saws
Can I use makita 5007nb circular saw on 220vAC.?
I have makita 5007nb circular saw. Its label says, 115v AC/DC? If its with universal motor {I assume} then can I use it on 220 VAC. As where I have to use it, there's no 110V supply
Posted by drwaqasanwar on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Makita Master
  • 36,386 Answers
I assume it will overheat and burn up at 220 volts. its not made for that. make up an outlet with one hot and a neutral off the 220 line
Posted on Feb 17, 2018
3 Related Answers
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Makita Circular saw 5007NB, the cutting depth
you can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
Posted on Jul 01, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: wiring varible speed swith for a Makita JR3000V reciporcating saw
The replacement switch, is it Makita and was it a direct replacement for the original part? That could make a difference. I looked at the schematics for this tool and they do not furnish the wiring codes but I think you are on the right track. To make sure though I would call Makitas tech support people at 1-800-4625482 and have a wiring explosion sent to you. Let me know if you still need more help and I will contact them or call a local dealer that I know.
Posted on Jul 26, 2009
H2_Brad
Brad
  • 425 Answers
SOURCE: how do you remove the
Just remove the brush caps. You may need to use a small pick or needle to pop the brushes out. In this diagram reference number 14 is the brush cap. They are just like a screw so you need to turn them to the left (counter clockwise) to remove them.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/5007NB
Posted on Jul 18, 2011
Why did it suddenly stop working?
Could be the cord. Could be the switch. Could be the motor.
May 16, 2015 | Makita 7 1/4" Circular Saw 5007NB
How do you remove the brushes makita 5007nb saw
Jul 05, 2011 | Makita 7 1/4" Circular Saw 5007NB
Where do I buy a power cord for a Makita circular saw and is it hard to replace?
You can go to www.eReplacementParts.com. I've have pretty good luck finding items. Make sure you have the model number available. Good Luck!
May 16, 2010 | Makita 7 1/4" Circular Saw 5007NB
Instructions or diagrams on how to replace a power cord for a makita circular saw.
here's a article on how to fix it.
http://www.amazines.com/Electronics/article_detail.cfm/78565?articleid=78565
May 05, 2010 | Makita 7 1/4" Circular Saw 5007NB
Cord replacement on skill saw model # 5007nb
the cord set you need is 664463-0, the wire guage is 2x14x8 SJ any repair shop should be able to help you with the proper wire guage cord for this tool. The installation is really easy after removing the handle half
Nov 05, 2009 | Makita 7 1/4" Circular Saw 5007NB
Makita Circular saw 5007NB, the cutting depth guide is jammed. What can I do?
Jul 01, 2009 | Makita 7 1/4" Circular Saw 5007NB
Saws Logo
61 people viewed this question
Top Makita Saws Experts
efs_perpends
efs_perpends
Marvin
Marvin
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
