I have a TCL HDTV, I cannot find a remote code to program the Summit remote to work the TCL TV. Summit doesn't list TCL in their brochure and TCL doesn't list Summit on their remote code list.
Posted by Sidney Freund on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 55,591 Answers
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Posted on Feb 17, 2018
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Posted on Jan 30, 2008
pdiggs
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
Anonymous
SOURCE: remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Posted on Nov 27, 2008
Anonymous
SOURCE: Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Posted on Dec 07, 2008
Anonymous
  • 110 Answers
SOURCE: can't program direct tv remote control to the tv
Try here:
http://www.twirp.com/en/index.php
Posted on May 23, 2009
Where do i find code to input for programming universal remote tv control
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 21, 2016 | TCL 24 in. Hdtv
What are the remote codes for a Summit Broadband DTA digital adapter remote to operate a TCL 26" HDTV?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
Jun 01, 2015 | HCDZ General Remote Replacement Control...
Tcl tv remot code
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Aug 09, 2014 | TCL 24 in. Hdtv
Remote codes for tcl tv
0238,0231,0222,0258. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts.
Jul 27, 2014 | TCL LE40FHDE3000 40" 1080p LED-LCD TV -...
Tcl manual
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 17, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
How do I program a Bright House Cable Remote control for TCL television
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Jan 25, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
PROGRAM MY UVERSE REMOTE TO TCL TV
0174,0179,0173,1070. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electro-medical.blogspot.com/
Jan 21, 2014 | Televison & Video
Televison & Video Logo
629 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
