Audio and video box keeps popping up . took batteries out of remote it is still doing it.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Testimonial: "Thank You it probably needs to go to the shop."
SOURCE: HDTV 52 INCH RCA
It could be a failing tac switch or the micro. The only way to tell is signal trace the switch circuit with a 20mhz scope.. Need a shop for that if you don't have the equipment and it's not terribly expensive...
Footnote: either failure can and usually will get worse over time and may infect other function, vol,ch, power and so on... Find a reputable shop and take it in.. If you have any problem location one let me know..
Bill
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
SOURCE: the picture and audio keeps
it could be a combination of things but here is a simple fix
unplug power from both the TV and Cable Box for at least 5 minutes
flip the HDMI cord wait 1 minute plug power cords back in
ENJOY
SOURCE: Element hdtv flx3210 shuts video off after a few seconds.
I have the same 3210 Element TV but with no audio at all.
