Question about Franke Coffee Makers & Espresso Machines
No milk and steam dispensing from Franke Flair coffee machine
I have just done descaling cycle on Franke flair coffee machine then no milk and steam dispensing afterwards, I can hear the machine churning then malfunction 4 came up. Nozzles and hoses for milk have been clean to make sure no blockage but still no milk and steam came out. Machine can do rinsing and dispensing hot water. Please help. Many thanks in advance. Solved, very happy finally found the problem and it works again :)
Posted by Widyana McLeod on
Stephen Lakos
    New Friend:
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Posted on Oct 01, 2018
5 Related Answers
ray gallant
  • 69232 Answers
SOURCE: How do I unblock the steam wand on my franke flair coffee machine.
Possibly with a small stainless wire .
Posted on Mar 15, 2016
Richard Brooks
  • 242 Answers
SOURCE: Hi, my Franke Flair does not respond when I push any of the buttons to make coffee, water, milk etc. it just displays the 'SELECT PRODUCT' message. The rinse, clean and descale buttons all work.
Unplug unit to reset the settings completely...If you have the same problem call manufacturer to save time...
Posted on Apr 05, 2015
Anonymous
  • 4 Answers
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Posted on Mar 21, 2009
frankecoffee
  • 29 Answers
SOURCE: our franke flair coffee machine keeps saying
this is usually due to the overtemp device activated on one of the thermoblocks, an engineer will be required to replace this item,
Posted on Nov 19, 2010
raj somaiya
  • 5370 Answers
SOURCE: Our Franke Flair is well cared for! Has been
Remove the water tank out.Then turn off the machine.Then turn on the machine.It will give message, water tank out or no water tank.Insert water tank then see.If it go further "please wait". But if its still not going beyond please wait, then its internal fault.The temperature thermostat is stopped working or its not heating inside.So the unit is just displaying please wait.The thermostat and heating element has to be checked and replaced.------------ This will help.Thanks.Helpmech.
Posted on Jun 02, 2011
Franke flair will not turn on i opened one of the coffee hubs whilst the machine was on after this it turnt of and now will not turn on i dont no what i could of possibly done i have opened it up to check...
I used to have a Franke Flair in an airport lounge. They are reliable machines. Remove the big electric plug from the outlet. Check the breaker and then plug it back in and switch it on. Make sure the bean hoppers are properly locked into place. The only problems we had with the machine was bean hoppers and the grinder mechanisms.
Dec 03, 2017 | Coffee Makers & Espresso Machines
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Franke flair
Where can I buy new seals or a whole new drop tray please
May 15, 2013 | Franke Flair Espresso Machine with...
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck [email protected]
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
enter programme button.push and hold for 5 secs.machine will show def product. press programme again to confirm.select product comes up on screen.press the product you want to adjust eg espresso.now use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Aug 17, 2010 | Franke Saphira Espresso & Coffee Maker
System fill message
Then it is a problem with the flowmeter. This needs to be changed, please contact your local dealer.
Aug 13, 2009 | Jura Capresso Impressa S90 Espresso...
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
626 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Dennis
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
