Question about Motorola Radio Communications
I bought a motorola xpr 6550 fr. Ebay and I can not connect with my two existing radio with the same model?
Posted by candido manansala on
John L radiodude365
    Master:
  • Motorola Master
  • 570 Answers
It is a business band radio, not a consumer radio. It must be programmed by a Licensed Two Way radio shop. The radios are programmed by a dealer for whatever frequencies (channels) the customer requires, so each radio can be programmed differently.
Posted on Mar 03, 2018
How do I change the power up volume level.
David
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Jun 23, 2015 | Motorola XPR 4550 Two Way Radio
Xpr factory reset
Contact Motorola Solutions Get Support
Mark MotorOla Support
Mar 29, 2014 | Motorola Radio Communications
Motorola xpr 6500: How do I reset to factory condition?
This type of radio requires programming with Motorola software and a programming cable.
Mar 20, 2014 | Motorola Radio Communications
I am trying to program a xpr 4550 with a talkaround channel that is the same feq as a repeater channel with no luck.
Be sure "talkaround" is enabled on the code-plug, then use the "direct" or "talkaround" button on the front panel.
Jan 28, 2014 | Motorola XPR 4550 Two Way Radio
Xpr 6550 no mic audio
Be sure the level is set correctly in the CPS software for your codeplug.
Jan 22, 2014 | Motorola Xpr6550 Vhf 136-174mhz 160...
Motorola 2-way Radio
There is very little the end user can do. You need the programming software which must be purchased from Motorola with a Licensing agreement. Or you take it to a Licensed Dealer and pay them.
Jan 02, 2014 | Cell Phones
I want to use a Motorola sport 7 radio with a Motorola T6550. What channel and code do I use?
  • Hi, the first 7 channels on both radios are standard FRS and will work together. Make sure no codes are on or they won't work until adjusted the same.
  • Frequencies for not radios according to channel
  1. 462.5625
  2. 462.5875
  3. 462.6125
  4. 462.6375
  5. 462.6625
  6. 462.6875
  7. 462.7125
  • The A,B,C channels on your sport 7 are GMRS repeater frequencies
  • A 462.5750 = Channel #16 on T - 6550
  • B 462.6250 = Channel #18 on T - 6550
  • C 462.6750 = Channel 20 on T- 6550
Hope this helps.
Regards, Tony
Oct 17, 2011 | Radio Communications
I want to use a Motorola sport 7 with a Motorola T6650. What channel and code do I use?
  1. 462.5625
  2. 462.5875
  3. 462.6125
  4. 462.6375
  5. 462.6625
  6. 462.6875
  7. 462.7125
  • Hope this helps.
Regards, Tony
Motorola talkabout fr 50 antennas are broken down how can I supply the antennas
Sorry, parts were not offered for this style radio. However, you might watch for used ones on ebay for replacement parts.
Best regards.
Aug 09, 2011 | Motorola Talkabout FR50 (14 Channels)...
Radio Communications Logo
93 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
