SOURCE: Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
SOURCE: Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
SOURCE: Dacor DCM24 - Security screw/tamper proof hex bit size?
It's a a T20H Torx type or GTXH20-100, available from hardware stores, or places like Lowe's or Wal-Mart.
Some folks just break or bend the post in the middle, then insert a small flat head jeweler's screwdriver in the space between the post & outer edge of the hole. A sharp tap with a hammer will loosen them a bit.
Otherwise, you can use a hacksaw or Dremel tool to cut a groove in them, then use a flat head screwdriver to remove them.
Just be sure that any special grounding screws get put back where they were to ensure proper grounding of the case, an important protection from shock hazard in rare cases of internal wiring breakage.
The Dacor DCM24 is essentially a rebranded Sharp R930A and I have the full service manual here at my site.
As to what's wrong with it, I would say your secondary interlock (bottom door switch) has failed.
The service manual will cover it, but there's additional info here: http://www.microwavedisplay.com/doorsw.txt
The best place to order Sharp parts is Tritronics.
SOURCE: Sharp R-1450 micro over range removal
Try removing the filters beneath the microwave. You'll find a large screw at roughly a 45 degree angle on each side. These screws bolt the microwave to the mounting panel in the rear.
SOURCE: Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
