Question about Firearms
I am interested in old break barrel air gun in .25 cal, where can I find them
Posted by Ellis Thomas on
john h
    Top Expert:
  • 23,438 Answers
Fixya is not a classifieds do online search or gun shop
Posted on Aug 18, 2018
Louis Bailey
    New Friend:
  • 10 Answers
Pyramidair.com
Jean DeLauche
  • 2,911 Answers
Hello, Ellis -
Air guns, used and new, are sold by firearms stores.
I have no idea where you reside, so I cannot even direct you to places in your area where firearms are sold legally.
Best wishes.
Posted on Feb 15, 2018
5 Related Answers
johnz1313
  • 88 Answers
SOURCE: Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Posted on Aug 11, 2009
Anonymous
SOURCE: old 1940 red ryder gun has no air coming out of
be sure you drop some oil in oil hole in barrel
Posted on Feb 11, 2010
Anonymous
  • 86 Answers
SOURCE: when i break the barrel it doesent catch.
Try to clean the barrel and make sure there is not an object jamming the spring.
Posted on May 30, 2010
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: I have 2 Daisy air rifles. One is a very common
i cant help you with a canadian source but i can with a british one try..
T W CHAMBERS & Co,,,e.mail,,[email protected],uk
if this guy dont have what you need il eat my hat after you have done some thing nasty in it???
Posted on Jul 14, 2010
Testimonial: "Thanks for the UK source, I never thought of that ."
agent91
Ned White
  • 2100 Answers
SOURCE: how do you load crosman quest 1000. never owned a
You load one pellet at a time when the barrel is broken open, the chamber is in the break of the barrel. One stroke, load, close, shoot, keeps you in shape. the old Sheridans, 10 pumps, really kept you in shape.
Posted on Aug 12, 2010
I have an Iver Johnson Cadet Model: 55S-A. 32 cal. 2 1/2 in BBL. 5 shots Serial No B27690. I would like to know more about the gun.
The Iver Johnson Cadet was offered as (the basic gun) as the Model 55 Target, and the 55A then the 55S Cadet and the 55S-A Cadet. The "parent" is discribed as: IVER JOHNSON MODEL 55 TARGET,Revolver,double-action,22LR,8-shot,4 1/2",6" bbls and 10 3/4"(6") 9 1/4"(4 1/2") over all length weight 24 oz.(4 1/2") 26os(6"); large frame,pull pin cylinder release with flash control front rim; recessed cylinder chambers;fixed sights,oversized molded one piece Tenite plastic target type grips; Does not have the "hammer the Hammer'action,matte blue finish; After 1958 cylinder is fluted hard chrome lined barrel introduced in 1955; dropped from production in 1979..the .38 caliber offering is designated as the Model 55S-A which is the same as the above except that: it was offered in .22LR,.32 S&W and .38 S&W(this is NOT a .38S&W Special) and as an 8-shot in .22, as a 5-shot in both .32 and .38. it is 7 1/2" oal w/ loading gate on the Right side AFter 1974/1975 this model is called"I J Cadet it was introduced in 1961 and dropped in 1979 Values: Vgood=$110..Good=$85 and Fair=$75. This data is from the Gun Digest Book of Modern Gun Values and more detailed Iver Johnson histroy can be had from www.gunshowbooks.com..check out Bill Goforth's Iver Johnson Arms&Cycle Works Firearms 1871-1993..Bill also frequents these forums and he along with Jim Hauff will likely correct any misinformation I may heve relayed as well as correct any ommisions.
Oct 04, 2018 | Firearms
How do i remove stuck pellets in the barrel of my gamo c 15
Hello, William -
According to the instruction manual for the Gamo C-15 Blowback firearm, you could use ". . . a 4.5mm caliber cleaning rod (.177 in) if a BB has become blocked in the barrel."
The information regarding a blocked barrel is on Page 11 of the instruction manual in the REPAIRS section.
If you do not have the instruction manual, this is the link to the PDF document (Adobe Reader software needed - free):
TinyURL link:
https://tinyurl.com/y9zwcvtk
The information is on Image 6, right side, of the PDF document.
(Quote from the instruction manual):
Repairs
A compressed air p1st0l (have to spell it that way or the Fixya algorithm reads it as a "bad word") that is not functioning well can be dangerous. Do not attempt to repair the gun yourself, since this may cause abnormalities in its functioning. Use a 4.5mm caliber cleaning rod (.177 in) if a BB has become blocked in the barrel. Take your gun to approved gunsmiths or to professional repair specialists approved for this type of product.
(End quote)
Best wishes.
Feb 22, 2018 | Firearms
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
Firearms Logo
208 people viewed this question
Top Firearms Experts
Marvin
Marvin
John Donghia Jr.
John Donghia Jr.
jws1013
Are you a Firearm Expert? Answer questions, earn points and help others
