When using toast setting in heat dial, the bottom side of the bread burns on one portion
SOURCE: Toast problem
i also have a gr82 but i don't have a manual and can't seem to find one online. can anyone help me with this?
SOURCE: can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
SOURCE: Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
SOURCE: toaster part of toaster oven
I would return the toaster and exchange or get a refund and get a different toaster. The switch to set is to bagel is probably not changing internally.
SOURCE: For HB 22708 Toaster Oven: Will it toast both
Yes, the Toastation works like a traditional toaster in the top slots. If it is not toasting both sides like a regular toaster then there is a problem. If that is so and if it is still under warranty, then contact the company for repair. If it isn't under warranty, then find a local repair business.
