Question about JVC Car Audio & Video
SOURCE: Diamond Audio amplifier 1200W
If the speaker wires touched and the protection circuit didn't engage quickly enough, the output transistors may have failed. This is the most common cause for an amplifier to go into protect mode.
If you disconnect the speaker wires from the amp and the B+ and remote voltage are above ~11 volts (place black meter lead on ground terminal of the amp when checking the voltage), and the protect light still comes on, the amplifier will need to be repaired.
Posted on Nov 25, 2007
SOURCE: Wireless WLAN
I have been working with Dell on this problem for quite some time. They tried replacing drivers, uninstalling and re-installing the card, replacing the card with a new one, etc, etc. Nothing worked. Sooner or later the error came back. Their last "fix" was to suggest that I restore the system to factory default condition and start all over again. I refused to do this. I had spent over 8 months adding software, tweaking it and windows, etc. They basically threw up their hands and gave up.
The Dell tech who replaced the card tried the solution noted here and "supposedly" it was fixed. A few weeks later the error came back.
So... I still don't have a fix for this problem.
If anyone finds one please let me know.
I'll check back here periodically.
Thanx,
Randy
Posted on Sep 19, 2008
SOURCE: 2000 Toyota Corolla.Dome light and clock not working
change the fuse AUX.
Posted on Aug 25, 2009
SOURCE: Odometer & gear shift indicator does not illuminate.
http://www.youtube.com/watch?v=84FAjLxoK00
Posted on Sep 08, 2009
SOURCE: my kw-avx840 was showing a
The faulty wire was shorting on the ground. When that happened the current flowing thru the amplifier top which that wire was connected got severely overstressed. This is why the safety system was triggering. By reseting it you were just making the problem a lot worse - you were forcing the amplifier to run with its output shorted. So it was to be expected that it eventually failed - it severely overheated and it got shorted itself internally. Now it's the short in the amplifier the one that is triggering the error message. And because the short is on a critical part you can no longer reset it - the power source itself has shut down.
The radio will have to be dismantled and the failed final amplifier identified and replaced, a job for a pro - time to take it to an electronics repair shop.
Posted on Aug 15, 2011
Oct 15, 2015 | Car Audio & Video
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V)
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Aug 04, 2014 | JVC KD-R530 In Dash Stereo
Oct 11, 2013 | JVC KDS-30 CD Player
Sep 25, 2013 | JVC KD-HDR1 CD Player
Apr 22, 2012 | 1996 Chevrolet Tahoe
Mar 22, 2012 | JVC Car Audio & Video
Aug 14, 2009 | Sony DAV-HDX500 System
Aug 20, 2007 | JVC Arsenal KD-AR560 CD Player
171 people viewed this question
