Cars & Trucks Logo
Joe Russell Posted on Feb 14, 2018
Can i fix a brake line with out have to replace the hold line?
1989 nissan d21 four wheel drive some body cut the brake line at the rear of the truck where it run from the top of the rear end back to the master cylinder and they replace a rubber hose and clamps so when press the brake pedal fluid come out from around the hose is there a quick way to fix it?
I need the right sequnce to bleeding my 04 nissan xterra abs brakes i changed all the brake lines new wheel cylinders in back
When bleeding brakes, you start with the wheel furthest away from the master cylinder and then the next furthest until you get all four done. On a left hand drive vehicle, you would first do the passenger rear, then driver rear, then passenger front, then driver front.
2helpful
2answers
Right front wheel pull to the right when i step on the brake why?
pulling to the right indicates no brake action on the left or no brake pads on the right
take it to an accredited brake specialist shop for a proper diagnosis and quote
Is there a website i can go on and get a estimate on engine mounts replacement before i take the vehicle into the shop?
easier to just ring several repair shops and get quotes
ask only accredited service shops or you run the risk of getting ripped of
1helpful
How can i rethread thuds on the wheel hub?
They will need to be replaced,
Remove the studs easily with a good hit,
Sml lump hammer works better than a claw hammer!
1helpful
What cause front brake calipers to seized up?
probably none of the above
have the brake master cylinder replaced first
then work on the pins that allow the calliper body to self center
probably seized on the pins holding one pad on the rotor
1helpful
2answers
05 nissan maxima, rear wheels locking up
Emergency brake cables are rusted. They wont release the E brake. Cut them or replace them.
3helpful
2answers
BRAKES LOCK UP WHILE DRIVING 1989 NISSAN D21
I am interpreting your description to mean that the brakes seem to work fine for a while, but then they fail to release after a period of driving. If sounds right, the most common cause for this is that one or more of your disk brake calipers is sticking, failing to release even after you let off the brake pedal. Normally, only one caliper will fail at one time, meaning that the vehicle will pull strongly to the side where the brake has locked up. You can also test this theory by driving your Nissan until it starts to drag. Pull over and lightly touch each of the tire rims. One or more of them should be hot--possibly burning hot--to the touch from all the heat that's been generated by the stuck brake caliper. A wheel with a properly working brake will probably feel warm to the touch--but not super-hot, unless you've just completed a motorcross course or something that gave your brakes a real workout.
You can buy rebuild kits for most brake calipers, but, in all honesty, it may cost almost the same and be better in the long run to buy a factory-rebuilt caliper, trading in your old one for its core. Factory rebuilt calipers are sandblasted and carefully cleaned and painted before the new parts are installed; quite frankly, I've never done any of that when I've rebuilt my own calipers.
It's possible that you might have frozen calipers even if both brakes on an axle (i.e., both front or both back wheels) are locking up. You might have gotten moisture into both of them by driving through a deep puddle, etc.--or you might not have noticed the problem until both calipers started acting up, holding back your car even more. I don't believe that your truck has any kind of special one-way pressure relief valves in the brake lines, outside of what's in your master cylinder.
Another cause for your braking problem might be your master cylinder. Ordinarily, master cylinder problems show up as loss of braking--your brake pedal goes to the floor or becomes very mushy. However, it's possible that a faulty master cylinder with some internal corrosion could be failing to release pressure after it's been applied. If you've excluded the brake calipers as a cause, this would be the next place I'd check.
A final thought is to think about the age of the brake fluid in your system. If it's older than a few years--or you can't remember the last time your system was flushed--chances are that the fluid is old and has absorbed too much water to perform at its original specifications. I don't think that water in the lines would tend to lock up your brakes, but you could try flushing out your brake system by bleeding all the lines and feeding a steady supply of fresh fluid into your master cylinder. Start with the rear brakes and bleed the front brake that's closest to the master cylinder last. This won't be a quick pump the brakes a few times and look for air bubbles kind of bleed. Instead, you'll want to pull out a half cup or more of fluid at each brake (more at the back, to compensate for all the fluid in the extended brake lines), ensuring that fresh brake fluid is being pulled into the brake lines and into the brake fluid reservoirs at the calipers and at the rear drums.
1helpful
I replaced all the brake lines then the bleeder valve(I am not sure of the actual name) cracked and exploded when I went to bleed the lines how do I fix it without going to a repair shop.
WHEN YOU BLEED THE LINES, IT WILL CRACK AND POP..ITS GETTING ALL THE AIR OUT ON THE LINES..START WITH THE PASS.SIDE REAR, GO TO THE DRIVER SIDE REAR, THEN PASS. SIDE FRONT THEN DRIVER SIDE FRONT..YOU HAVE TO START WITH THE WHEEL THE LONGEST DISTANCE FROM THE MASTER CYLDER.. HAVE SOME ONE THE PUMP THE BRAKES THREE OR FOUR TIMES, ON FOUR TIME HAVE THEM TO HOLD THE PEDAL DOWN, THEN LOOSEN THE BLEEDER VALVE (WITH THERE FOOT STILL ON THE PEDAL) AFTER YOU LOOSEN TIGHTEN BACK UP AND REPEAT THREE OR FOUR TIMES ON EACH WHEEL.. BE SURE TO START WITH PASS. SIDE REAR, SO ON AND SO FOURTH.. THIS WILL FIX YOUR PROBLEM..GOOD LUCK KEITH...
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
