Question about Mercury Boating
50hp mercury 3 cylinder outboard the ldentification plate is partly damaged what I think is S288735 the motor has a intermittent spark on one plug have. Changed leads and plugs still the same
Posted by David sawyer on
5 Related Answers
Anonymous
SOURCE: Rear cylinder not firing
95 Evo, new plugs, new wires, started backfireing like a machine gun, front cyl. no spark at plug sometimes - would this be the coil, have not ohmed the coil yet . Thanks
Posted on May 13, 2009
Anonymous
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
Anonymous
  • 301 Answers
SOURCE: oil in 1 1997 chrysler lhs spark plug tube
although I am not familiar with this particular engine my son's Mazda Miata had oil in the plug holes and it only required a new valve cover gasket to fix it.
Posted on Oct 18, 2009
muffteck
Frank England
  • 202 Answers
SOURCE: wiring diagram for 1982 Mercury 6cyl outboard tilt
go to ebay and buy a manual
Posted on Mar 27, 2010
Anonymous
SOURCE: I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Posted on May 20, 2010
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
50hp blue band mercury .crack in plate port side leaking water
if its got about 18 bolts on it and aprox 12by6 inch in size then thats the exhaust plate !
remove all bolts and remove plate and then a s/steel plate , check for corrosion and damage etc ! clean all gasket faces and replace gaskets and put a light film of gasket glue on all areas where gaskets touch and refit !
Feb 28, 2015 | Boating
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
No spark on a 2005 50hp mercury outboard
If power to coils is intermittent, you need to find out why. Follow the wiring back from the coil to the source of the power, look for wire damage or water getting in. Disconnect the wire at the coil end and use a multimeter at the other end to see if there is any power there.
Oct 20, 2013 | Saws
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
I have a mercury outboard 50hp engine that will not start
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
May 27, 2010 | Boating
Boating Logo
43 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
