Question about Jensen Audio Players & Recorders
New jensen cd-725 will not play cassette....tape icon does not show in the display window....neither does the FM show in the window.
Posted by K Walters on
5 Related Answers
Anonymous
  • 215 Answers
SOURCE: head cleaning
Quite often just the one clean won't dislodge the gunk built up on the heads. Make sure you use a new wet system head cleaner and you may have to run it a few times to clear the clog. JUST DON'T USE COTTON BUDS OR WOVEN RAGS. BMW
Posted on May 18, 2006
Anonymous
  • 4402 Answers
SOURCE: "Reinsert the Cassette"
go here
Posted on Jun 11, 2008
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
daniel
  • 5 Answers
SOURCE: Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
i have the same deck with same problem..so this is the typical problem for this deck...got it from thrift shop..it was in perfect condition, working excellent but after few days of enjoying it, all of a sudden the same problem arises.... and the motor is abnormally hot..it is way too fast.
when i switch on the power the middle motor will automatically turn on at very high speed...i play around anything i can do hoping something is just stuck up but to no avail..
Posted on May 19, 2010
cbast2
SOURCE: Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Posted on Sep 04, 2010
HOW DO I GET SOFTWARE FOR JENSEN JSCR50 CASSETTE USB
Either by purchasing a new unit from Amazon.com as linked below or by .zip file download from the attached links. Jensen Cassette Tape to MP3 Converter Free Download Streaming Internet...
Cassette player doesn't work
tape is in wrong or heder needs to be cleand.
My component is in LINEAR PCM MODE when it start playing dvd/cd no sound comes out. while in CASSETTE TAPE, it has a sound. i want to know what is this LINEAR PCM, coz i notice, when i turn FM it has a...
LPCM is for digital sources ONLY. Your cassette wouldn't be digital would it? FM, being an internal source on your unidentified receiver CAN'T be wired or configured incorrectly. Crack the manual open and find out how to set the parameters for all the digital inputs, then connect and select an analog input for the tape.
3helpful
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
2answers
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
5helpful
CDR/ipod Not Connect wondow message
Select another function, fx V. Aux, then press menu-button. The display should then show "Ipod assign". Use select to find "Ipod: none" and press Enter...
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
