R
Richard Houser Posted on Feb 13, 2018
I need to replace the Trans Board on my Sony CX 455 player. Any leads to a source, new or used?
Need manual for a Aiwa cx_na777
Certainly! Here is a basic manual for the Aiwa CX-NA777:
  1. Powering On and Off To turn the CX-NA777 on, press the Power button located on the top right of the system. To turn it off, press the same button again.
  2. Changing the Volume Use the Volume control knob located on the front of the system to adjust the volume. Turn it clockwise to increase the volume and counterclockwise to decrease it.
  3. Selecting a Source To select a source, such as the CD player or the radio, use the Function button located on the front of the system. Press it repeatedly until you reach the desired source.
  4. Using the CD Player To use the CD player, press the CD button located on the front of the system. Insert a CD into the tray and press the Play button to start playing the CD.
  5. Using the Radio To use the radio, select the Radio source using the Function button. Then use the Tuning knob to tune into the desired station. You can also use the Preset buttons to quickly access your favorite stations.
  6. Using the Tape Deck To use the tape deck, select the Tape source using the Function button. Then insert a cassette tape into the deck and press the Play button to start playing it.
  7. Adjusting the Sound To adjust the sound, use the Bass, Treble, and Balance controls located on the front of the system. These controls allow you to adjust the bass and treble levels, as well as the balance between the left and right speakers.
  8. Using the Clock and Timer The CX-NA777 features a built-in clock and timer. To set the clock, press the Clock button and then use the Tuning knob to set the correct time. To set the timer, press the Timer button and then use the Tuning knob to set the desired start and end times.
  9. Using the Remote Control The CX-NA777 comes with a remote control that allows you to control the system from a distance. The remote control features buttons for all of the main functions, including Power, Volume, Function, and CD playback.
  10. Troubleshooting If you experience any issues with the CX-NA777, such as a CD that won't play or a radio that won't tune properly, consult the user manual for troubleshooting tips. You can also contact Aiwa customer support for further assistance.
Note: This is a basic manual and may not cover all features of the Aiwa CX-NA777. For more detailed instructions, please consult the user manual that came with your system.
Can I use A/C cord to play Coby CX-CD329?
Cx 300 won't read cd it says no disc after i replaced optical laser lens
If you have fitted a new laser assembly, have you removed the blob of solder that protects it while fitting, it's on the board underneath across two tracks
1helpful
How to remove the cover of CDP CX 455?
Take the screws out of the sides, top, and the screws on the back that go into the cover. then lift up.
1helpful
I need to hook up the dvd player to my new Sony
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
3helpful
3answers
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
1helpful
Sony CDP CX-300
Hi try and visit
http://www.usersmanualguide.com/sony/dvd_sacd_cd/cdp-cx300
You would need adobe pdf software to download this. Dont forget to rate Fixya, ty.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
