Question about Mitsubishi Televison & Video
Mitsubishi wd-y57 dlp tv.The component inputs do not function properly. There are lines and the picture is dark. Hdmi inputs work ok. I hve checked cabels and the are fine.
Posted by Matthew Heckman on
Larry
  • Mitsubishi Master
  • 2,800 Answers
If your cables are ok you have an issue with the main board .
Posted on Feb 13, 2018
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
micromaster
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
mpservices
  • 191 Answers
SOURCE: hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Posted on Nov 27, 2008
Azrael SRL
  • 11800 Answers
SOURCE: HDMI inputs don't work
No, but the HDMI interface is very sensitive to static discharge - has been a storm nearby? To prevent this from happening again i usually install to all my customers cheap splitters just before the tv, they will fry before the tv protecting it.
I'm sorry but it's time to change that board again.
Posted on Jul 26, 2010
Chi Chu
  • 8457 Answers
SOURCE: I have a mitsubishi 60
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Posted on Oct 18, 2010
I have a Mitsubishi WD-Y57 1080P. I knew that my bulb was about to go because it was getting dim. I have replaced the bulb twice in the past. This time however, the day before it totally died, the...
Is your remote control possibly bad? Is it set to other than TV mode? Batteries? Nothing to do with lamp, but TV must turn all the way on for remote to operate anything besides power on/off. --Remote is a function of TV microprocessor.
May 25, 2014 | Mitsubishi WD-Y57 57" Projection HDTV
Hdmi inputs are not working on my mitsubishi WD65738 DLP
That TV is suppose to have automatic input detection but if it doesn't work you can press the input button on the remote and then use the arrows and enter to select the input you are trying to use.
Dec 12, 2013 | Mitsubishi WD-65738 DLP TV
Hdmi inop all 3 inputs
First thing to check is that you actually have a source signal FROM the HDMI output. Second thing to check is the cable. The audio is embedded into the signal path, so if you don't receive picture, then you shouldn't receive audio.
Check the above on a neighbours set etc, before then having to check TV settings. Finally, do a factory restore on the TV set, via the menu driven software.
Nov 20, 2013 | Mitsubishi WD65737 65" DLP TV
Mitsubishi tv- sony 1030 avr hdmi connection no picture
Just to clarify. You have the proper inputs selected on the TV and the proper output on the reciever?
Jan 24, 2013 | Mitsubishi WD-Y657 65" HDTV
Dlp blurred dark picture
The lamp unit is most likely bad but other things can cause this, age of set: average life on a lamp is 2000 hours or two years.
Dec 22, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
I have Mitsubishi WD-Y57 DLP. Replaced lamp and now green timer comes on for a minute or so and then turns off. TV will not come on?? HELP!
I have the same TV. Mine is almost 3 years old. From what I've learned you should try to reset the TV. There is a small button in the front input compartment. Use a pen to push that in and wait for the green light to stop blinking. Then try the TV.
If that does not work you probably need a new lamp. Apparently the lamps only last for a couple years on average. Having to replace them can really add to the cost of buying/owning one of these TV's
Nov 21, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
Single HDMI Input. Need to connect several HDMI components
Number 1 would be to connect the 3 Devices to a Receiver with 3 HDMI Inputs, So this way you get the HDMI Audio as well. 3 in and 1 out to the TV as you know. The other way would be to get a Key Digital HDMI 3 to 1 Switcher. I have used these a lot in the field on installs and they work Great. They also have 4 to 1 if you think you might need more. No programming of the piece you just plug in and setup your TV in the HDMI Menu and your other Devices. If they don't sync AUTO! The Receiver would be Best I feel, Some let you assign 2 different Video and Audio sources at once. Such as Video from a Game and Audio from a CD. Hope this helps out!
Apr 20, 2009 | Mitsubishi WD-73833 73" HDTV
WD-62525 horizontal lines in picture when using component inputs
code 12 means the set isnt experiencing any shutdown symptons. I would check for more capacitors in the same circuit where you found the other often they show no visible sign of deterioration. If you need a service manual to figure out which capacitors are in that same circuit you can get the manbual for your set for 10.99 at the following link. They will even email it to you if you go back to the site and let them know you want it emailed. heres the link hope it helps.
http://servicemanuals.vstore.ca/
Jan 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
