Televison & Video Logo
Question about Alba Televison & Video
I hae a tv/dvd combi ALBA MODEL LCDW16DVDHDP and hav just got a new remote but dont know how to link it together, could you please help. Thanks
Posted by Karen Watkinson on
5 Related Answers
Anonymous
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Alba TV
I would suspect that the optical pickup is faulty. However Alba sets are manufactured in Albania therefore parts are not readily available.
Posted on Feb 03, 2008
Anonymous
  • 476 Answers
SOURCE: I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Posted on Feb 18, 2008
Anonymous
SOURCE: bush tv/dvd combi
your daughter has done nothing wrong, certain dvd,s have region codes for different countries.you can program the player with your remote, but you will need the hack number.i,m looking for it myself, so if you find it,pass it on!
Posted on Nov 25, 2008
Anonymous
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
hi my bush modle is btv183dvd\c i live in iran but i didnot buy this in iran well i listened that this modle has code ( if you kepp the negative switch volume on your tv & in that time push & keep the number 6 on controler ) you can see very much codes please dont change thoese
but i changed thoese and know i cant search for channel and it cant show that channel that befor time show that
please help me thank's
im armin
Posted on Jun 28, 2009
I have a alba Lcdvd tv which is in dvd mode how to change to bbc or itv dont have a remote
hello some of these new tvs have an all in one switch bottom right press it in, either move up or down for either tv or dvd, thanks, ps if it's an oldish tv press source or input on the side of the tv
shaun
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
1helpful
Urc 7130
If you do not find any set-up code by its code list, just try a code search method. Sometimes, you might succeed. Common codes to check with Alba brand TVs are, 1061 1206 10511210 1075 1130 1083 1032 1225 1147 1157 1190 1052 1035. If you wish to get more check the site linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://remotesearch.blogspot.com/
1helpful
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
Alba led16911dvd
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
2helpful
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
I need codes for a remote ,BD512
there are no coides published for ALBA TV ,try Pressing SET (&hold)and (1) key ,indicator will flash eg. 4 times for Digit 4 etc,repeat this step ,with (2)key for the 2nd digit and (3) key for 3rd digit,good luck
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
