Using Smart Switch to transfer data from phone to phone, which phone does the SIM card need to be in?
SOURCE: Data Transfer to new phone
you can get USP cable for your phone, I suggest you get it from eBay, it would be 1.00$ and almost 4.00$ shipping.
take care
SOURCE: all incoming calls go straight to voice mail
Just go to call settings and then call divert. check settings. Maybe all calls are diverted to voice mails. Cancell all diverts. Then you are done.
SOURCE: I cannot send and receive
If you can make calls, then it's issue with the service provider. They probably didn't activate your txt features for your account. Call Smart Network to activate. If you can't make calls, then the issue is likely with the SIM card. You need a replacement. Either way, call Smart Network and they will provide you with a new card
SOURCE: HOW DO I TRANSFER ALL
Regarding your Question we/I can't explain.
Because you didn't elaborate/explain your Phone/hand-set Model etc.
For transferring all data won't be possible but contact no. would be possible.
For example if you are using X2-01 Nokia hand-set
Follow this instruction and see whether it's helpful to you or not?
(Moving or copying contact no. from Phone to SIM)
1. Menu
2. Contacts
3. More
4. Choose Move contacts/Copy contacts
From Phone to SIM
Thanks for using FixYa
All the Best!
SOURCE: want to unlock/jailbreak straight talk samsung
Jailbreaking in IOS is rooting in Android. You root the Precedent (gain access to the root login) by using rtto at http://codegeekbbs.com/samsung.php Just follow the directions you'll find in the file. Just read the Readme.txt file.
Unlocking is making the phone run on other carriers' towers - and you can't do that with a CDMA phone without pretty much rebuilding the phone. (CDMA phones don't have SIM cards, only GSM phones do - the technology is different.)
