SOURCE: keyless reprogram
resychronizing the key works.
1. Insert key into ignition and turn to
position 2.
2. Remove key and hold down lock button
while pushing unlock button five times.
3. Release all buttons, then push either lock or
unlock button.
!!!!!!!!!!!!!Procedure must be completed within10
seconds.!!!!!!!!!!!!!!!!!!!
SOURCE: remote keyless entry not working
KEY FOBS FOR THIS MODEL MUST BE PROGRAMED USING A TECH 2 SCAN TOOL SO IT MUST BE DONE AT THE DEALERSHIP FOR ABOUT HALF HOUR LABOR HOPE THIS HELPS
SOURCE: 1998 nissan altima gxe -ignition problem
Hi what is happening is that your turn off your car and left the wheels turned to one side and specially if your car is parke in a hill what you have to do is to force the steering wheel to the same direction of your wheels this will free up the ignition switch it is going to be hard let me tell you but it will work and this is why your shift don't work once you have the ignition switch free then your shift will work again
SOURCE: programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
SOURCE: Where can you purchase battery for keyless entry for 2007 Nissan
The best place to purchase a replacement battery is AutoZone. They have a tester there to make sure everything is working. It should be on the help counter.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
