Hello, George -
I am sorry it was too difficult for you to go to the Cuisinart web page for parts for your Cuisinart DCC 1200 coffee maker.
This is the link to the web page where you can purchase a replacement carafe lid or a complete replacement carafe:
https://www.cuisinart.com/parts/coffee_makers/dcc-1200/
Best wishes.
SOURCE: dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
SOURCE: DCC-1200 Coffee Maker
See post on Cuisinart customer service. The tube can be purchased at Lowes. Clear vinyl 1/2" O.D., 3/8" I.D. The compression clamp will have to be replaced as well.
I used a 1/2" hose clamp available at any auto parts store.
SOURCE: Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
