Question about Frigidaire Ovens
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
Everything else on oven & stove work
Posted by Diana Mazzarella on
vince
  • Frigidaire Master
  • 1,234 Answers
Answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Posted on Feb 12, 2018
Testimonial: "Thank you. After power surge I unplugged the oven. New Breaker was installed and we plugged oven back in. that is when DR code came on. Tried unplugging and plugging in again still happens."
  • vince Feb 12, 2018
    here's a site to get the door latch.
    http://www.appliancepartspros.com/frigid...
    they also have a 877# for tech and install support.
    I've used them for parts for our rental units and have found them to be quite helpful.
    re-verify model # on the site page.
    Best to you.
5 Related Answers
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: GE JGRP17 Gas Oven
Rosanne, he problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN OR TURN IT OFF AT THE BREAKER!
To replace it... Remove the racks and look up at the broiler manifold. You'll see the igniter mounted at the rear (the round thing with 2 wires going to it). You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter, tuck any loose wires as far back into the oven as possible and replace the racks.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Posted on Oct 11, 2007
Anonymous
  • 288 Answers
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Posted on Nov 11, 2007
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Anonymous
  • 22 Answers
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Posted on Jun 26, 2009
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Im getting F13 on my oven display when trying to use it?
Sabrina I do not see an F13 Error Code for Whirlpool, Try unplugging oven for a few minutes and then plug or switch power back on from breaker and it should reset. Also send the exact model number located inside your bottom drawer door or oven door. Here are all the codes listed for Whirlpool=> Whirlpool Fault Codes You also can find your user manual here=> Whirlpool User Manuals and model number Locator's here=> Model Number Locator's I have spent a lot of time trying to help and will be happy to assist you if you have more questions, Thanks, Sea Breeze
May 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Feb 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Error Code F13 and door locked
press clear for five seconds if that doesn't work then power down for 30 seconds then on if that doesn't work replace the eoc
Mar 19, 2008 | Frigidaire FEB30S6D Electric Single Oven
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Ovens Logo
472 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
