Question about HP LaserJet Office Equipment & Supplies
Hp laser jet m1522 printer has sat dormant for a couple of years. Trying to use it again and when I turn it on it cycles but led screen stays blank.
Have not been able to download driver either for MacBook Air
Posted by Mick Wheeler on
5 Related Answers
Anonymous
  • 159 Answers
SOURCE: blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
Posted on Apr 05, 2008
Anonymous
SOURCE: driver hp laser jet 1020
hp driver 1020 downlord
Posted on Nov 05, 2008
Bart Fonteyne
  • 130 Answers
SOURCE: hp laser jet 1018 printer driver for windows xp
You can find the driver here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1814092
Please rate, thks.
Posted on Jan 30, 2009
Anonymous
SOURCE: Free HP LaserJet 1300 Printer Driver
i don't have priter driver for HP Laser Jet 1300 printer, can i download it, how to download it?
Posted on Mar 11, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
If i on the laser jet m4345 mfp printer the three light will be on and the control panel will be blank
The Rom / firmware on your formattor board maybe the culprit. Turn printer off and remove one chip at a time from formattor board to see if LED changes its state. If it does'nt replace you formattor board.
Dec 04, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
My hp laserjet m1522 powers on then hangs
Check voltage between 1 & 12 connector J32 on formatter should be 5V, if no replace DC controller(engine controller PCA),P.No RM 4932-000cn(120V), RM4936-000cn(220V).If voltage is good replace Formatter..P.No.CC396-60001
Oct 18, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp laser jet m1522nf formtter hanging problem when we start the printer after hewlet packed and prrocess with errow after five errow formatter hang -------please give us solutins
This model is covered by a service advisory by HP. Basically any M1522 manufactured before January 1, 2010 is covered should this type of failure occur. You only need to contact either HP directly or an authorized service partner. You may have to be insistent because I have found some HP staff and dealers are not aware that this free fix is offered. Contact Hp at 1-800 HPINVENT
Apr 14, 2011 | Office Equipment & Supplies
Why is My HP Laser Jet M1522 mfp printer is printing out black pages?
probably catridge problem. The drum is not charged correctly
pifonski
Apr 07, 2011 | HP LaserJet M1522nf Multifunction Printer...
How to install HP laser jet M1522nf and connect my
How are you connecting this printer to your computer ? usb or network ?
If its network i would recommend you to make sure that the IP Address on the printer matches with the one set on the printer driver on the pc
Tryn reinstalling the software a detecting the printer automaticly
Jul 07, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
Printer problem
First remove the control panel from the machine and make sure that the cable is seated well to the panel and the control board. If they are remove both cable ends and reseat them.
May 21, 2008 | HP LaserJet 4250n Printer
Blank display
correct voltage.
Apr 04, 2008 | HP LaserJet 4250n Printer
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
