Question about HP LaserJet Office Equipment & Supplies
PRINTING BLANK PAGE HP LASERJET M1132 MFP - LaserJet HP Office Equipment & Supplies
Posted by job isaac obado on
5 Related Answers
Anonymous
SOURCE: HP LaserJet 4 printing vertical lines all down and across page
sounds like your fuser assembly needs to be repaired. you can get the parts online fot about $40USD.
Posted on Mar 29, 2008
Anonymous
  • 38 Answers
SOURCE: My HP Laserjet 1320 is
Shake the toner cartridge.
Posted on Dec 17, 2008
Anonymous
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
Walid M Sayed
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
Anonymous
SOURCE: HeLp! My HP CM2320nf MFP is printing blurry!
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
Posted on Mar 08, 2011
How remove e3 code in hp leazerjet m1132
http://h30434.www3.hp.com/t5/Printing-Issues-Troubleshooting/error-E3-on-my-HP-laserjet-M1132-MFP-printer/td-p/3914982
Feb 11, 2015 | HP Office Equipment & Supplies
Printing blank page
Are you setting this up for the first time and the pages are coming out blank, or have you been using this and all of a sudden, you have blank pages coming out?
In the meantime, take a look at link and let me know if the steps help to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01760759&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3811337
Thanks,
HP Printer Support
May 30, 2014 | HP LASERJET PRO M1132 MFP
I am unable to make photocopy on laserjet m1132 mfp
i have paper and ink but mu photocopy can make anything can't laod any paper so tell me the solution
Feb 17, 2014 | HP LASERJET PRO M1132 MFP
Hp laserjet m1132 refill problem solution
Replace with professionally remanufactured toner... it works better... or increase the resolution if you are copying...
Sep 28, 2012 | HP LASERJET PRO M1132 MFP
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice.
Nov 19, 2010 | Office Equipment & Supplies
321 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
