SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Whirlpool Cabrio sounds like a jet engine while
believe the bearings can be bought locally,but water seal has a Whirlpool number on it that will not come up on pricelist on my Whirlpool program.I am looking for a way to cross ref. this seal and repair the tub.The last tub was over 197.00 cost for new tub and drive shaft ,bearings and seal.The bearings are Korean made and can be bought locally for alot less than a whole new tub.This is an ongoing problem with the Cabrios and Maytag Bravos that I have seen lately.Also a few of the Sears Kemores out there.There has to be an easier and cheaper repair for these thousand dollar machines.I dont like telling the customer its going to cost them 400.00 to repair their washer when it is not even a year out of warrentee.If anyone has the seal number or a cross number please post
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
