Try a different brand of needle . Cheap Chinese are made to small.
Testimonial: "I am using Schmetz, a very good brand. I have tried three different needles from three different packages. Also, had my husband use Micrometers to check the diameters of the three different needles and they all measured to within .0005 of an inch. I think my problem has something to do with the cam and the little screw that's held within the needle clamp. Just wondering if a Viking/Husqvarna person had any information about the problem?"
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
There is a hidden screw just that looks like a hole beside the screw that hold the needle... loosen it with # 8 allen key (pretty small) then you put the curved wire back in its hole, then you can put it back on the arm, then screw back the allen screw as tight as you can, this should do the trick worked for me ... I was tring for days to fix it back on but wouldnt go in...this invisible screw was to tight... Hope it helped !
