Question about Frigidaire Kitchen Ranges
I have a frigidaire range model fgf366ecc and got code F31 what does that mean?
Posted by Billy Watts on
5 Related Answers
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: What does the error code "F12" mean on a
Sorry to read about your problem, I hope this helps you out.
You have a defective keyboard or clock issue, you will have to contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
reg501
Richard
  • 413 Answers
SOURCE: pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Posted on Jun 10, 2008
Mike McWhinney
  • 537 Answers
SOURCE: oven does not start and gives code 31
Check this link:
http://www.applianceblog.com/mainforums/showthread.php?t=11880
It sounds like your oven probe is failing or has failed. The control board could possiblly be bad too
Posted on Apr 18, 2009
David S.
  • 506 Answers
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
Posted on Dec 15, 2009
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: I have an error code F31. What does this mean
f31- suction pressure protection. Short gas or no gas. Check for leak and rectify.
Posted on Jan 03, 2011
F31? What DOES THIS MEAN?
Not a do it yourself repair other than the turning off power for ten minutes method.
example:
http://www.manualsonline.com/support/frigidaire/oven/what-does-f31-mean-5368413
Jul 10, 2018 | Kitchen Ranges
Turn on over and get F31.
Hello, Janice -
There are many ovens in use today. It will help to know the make and model of your oven. You can add that information by choosing Comment and typing in the make and model of your oven
If yours is a Kenmore brand oven, the F31 error code means that the oven temperature probe has shorted out or there is a shorted sensor probe harness connection.
Sources of information + repair instructions:
https://www.shopyourway.com/questions/1068107
and
https://www.shopyourway.com/questions/1036659
If your oven is a Frigidaire gas oven, then the F31 error code also means there is shorted oven temperature sensor probe or a shorted sensor circuit.
Source of information:
https://www.shopyourway.com/m/questions/1018474
I hope you have the owner's manual for your oven. The F31 error code will probably be described in the manual.
Best wishes.
Apr 01, 2018 | Kitchen Ranges
What does F31 mean on Frigidaire stove?
Thank you for your inquiry, friend!
Based off what you have described your Frigidaire range is displaying an F31 error code and you would like to know what it means. An F31 error code means a shorted probe connection. This could be a possible problem with your sensor probe, control panel, or probe connector. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue you may need to seek help from a professional technician for proper diagnosis and repair. Best of luck! -Matt
Aug 12, 2015 | Frigidaire Kitchen Ranges
/lfgf3014lbcwhat does f31 mean
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Mar 30, 2015 | Frigidaire Gallery 30" Self-Cleaning...
What does f31 error mean on fregidare gas range
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
F31 on my Frigidaire oven how do I fix it?
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
Code f31 shows when try to turn on oven
F31 means there is a short in the oven cavity probe circuit. The probe is the one of easiest things to replace. But this could be a control as well. To start, remove power from the range, unplug it. Remove bottom backguard panel, look for two purple wires leading down to a small white connector, which will lead you to a rectangle piece of metal (approx 1 X 3/4in) with one corner tucked in the body and a screw on the other end. This will be located on the right hand side of the back about half way up. Once you remove the screw, twist from the corner, slide out gently. http://b2b.frigidaire.com/support/manuals.asp?user=&NewSearch=New+Search will provide documentation for a part number for the "probe" or may be called "RTD."
I would be glad to provide more detail if you like, I would need more details in return...
Aug 29, 2011 | Frigidaire Gallery 30" Self-Cleaning...
When I try to turn on oven the code F31 shows
Hi and welcome to FixYa,
I am Kelly
See this link:
http://www.applianceaid.com/faultcodes3.html
Scroll down past mid page and read F31
Your Temp probe is shorted. It shuld read around 1091 Ohms (+or- 5.3 Ohms) at 75 Deg.
If you respond with your model number I can point you to parts sources.
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Frigidaire Kitchen Ranges
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jan 16, 2010 | Kitchen Ranges
Starts beeping and F31 ERR flashes
Any F code error indicates a fault has been detected . Press Clear/Off to clear display and stop beeping then reprogram the oven. If the fault reoccurs record the fault number press Clear/Off and contact an authorized service agent. If you have access to the internet you can download a manual for this appliance go to www.frigidaire.com/support/support.asp
On the customer services page click on product manuals and you will be abe to download the manual and print it off.
Apr 21, 2009 | Frigidaire FEF352 Electric Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
