SOURCE: Setting time on Seiko watch 7N43
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
SOURCE: Unable to set time and date on a vestal G5 global traveler watch
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
SOURCE: need operating manual to set time and date
Just posting a solution to remove this from unsolved problems list. thanks and good luck.
SOURCE: lost manual to Coleman nightsight
The manuals for Coleman watches are at this website. . .
http://www.gsi-usa.com/instructions/
You need to look at the back of your watch to get the model number.
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
