SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
SOURCE: fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Testimonial: "Thank you coachtheune. I appreciate your help."
SOURCE: How do I winterize my Mercury outboard 115 HP
Just need to lower the motor all the way down. This will drain all the water out of the motor. That should do it. They recommend changing the motor oil at the end of the year or the start of the next boating season. You should also add some Sta-Bil or Pri-G gasoline additive. Think it's available at Wal-Marts or part stores. Probably a good idea to keep the fuel tank full to prevent air inside tank from condensing and forming water. Add a couple of cans of HEAT to fuel to help keep water out.
Guess I need to be more specific, Model # 115FXLPT repair manual
