Televison & Video Logo
Question about Alba Televison & Video
Using back of tv to retune on my ALBA TV but it is stuck on GBR which button do I press at the back to start
Posted by teresa on
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Alba TV
I would suspect that the optical pickup is faulty. However Alba sets are manufactured in Albania therefore parts are not readily available.
Posted on Feb 03, 2008
Anonymous
SOURCE: tv code for Alba 14" tv
i have a controle watch but i can not find the right code setting for the alba tv so i can't do anything with it.
Posted on Dec 10, 2008
Anonymous
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
Anonymous
SOURCE: alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Posted on Feb 22, 2010
Testimonial: "Excellent! It works, many thanks for your help"
David Cunliffe
SOURCE: alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Posted on Nov 19, 2010
MY ALBA TV SAYS NO SIGNAL EACH TIME i PLUG IT IN
Either the TV has lost its memory and just needs retuning; or your coax and/or aerial is stuffed.
Told my TV to retune analogue by mistake. Now it
Press the TV/DTV button to toggle between the two tuners.
How do I retune alba tv
UNKNOWN BRAND TO ME,but check on the internet for alba tv..horst in aussy land...
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
I have just purchased an Alba LCDW16DVDHDF and it is not picking up all the freeview channels (including BBC). Is it a problem with the TV or with the signal from the aerial?
By pressing the volume + & - buttons at the same time on the TV itself you will bring up the master setup menu.
From here you can select first time installation and the TV will auto retune to the new digital stations
154helpful
5answers
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
28helpful
4answers
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
1helpful
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
