Question about Dual Audio Players & Recorders
Dual internet radio , connection to earphone damaged , hence radio main speakers not working
Sound on earphone still working
Posted by Peter herrmann on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Line Out/Headphone Audio Connector not working
Yes it is possible to replace the connector itself. It is a bit costly, but much less than a new motherboard or new laptop. It is not something that is easily done, as it does requiring soldering on the board, which if you are not familiar with this, it is not something to attempt, as you can short out the board. There is a company out of Ohio that I would recommend you contact, their phone number is 513.874.3306. You can also email them at [email protected] They also offer a diagnostics special through eBay by clicking this link
Hopefully this will help you out.
Posted on Nov 26, 2007
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: 2004 Harley UC Radio - no sound on Left side
how about the antenna this could be the main problem im not a motorcycle expert but radios i do know and if your getting static the antenna which is called the aireal << spell check is not picking up enough signal
also head phones could be also a bad set
Posted on Jun 10, 2008
Anonymous
SOURCE: Sound problem with Aspire 5570
I had the same problem with my Acer 5570 and I just fixed it. What I did is to go to Control Panel > Sounds And Audio Devices >Hardware >On Devices click on Reatek High Definition Audio >Click Properties > On Devise Usage choose the option Do not use this devise (disable) > click OK >then plug in your headphones, click on Realtek High Definition Audio properties again and click on Enable Devise **with the headphones plugged in**. It worked for me.
Posted on Nov 25, 2008
Anonymous
SOURCE: 'phones engaged' no sound
Well,
My onkyo receiver was keep displaying "Phones Engaged" and no sound.
All I did was plugged in a phones plug and remove it and for the last 2 weeks there is no problem.
I just happened to have a phone plug (without the actual headphone or wires) and that seems to fix the problem.
Hope it will work you all of you as well.
Good luck.
Posted on Jul 30, 2009
Larry Gutman
  • 239 Answers
SOURCE: Changed Radio - now speakers don't work.
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Posted on Jan 19, 2010
Testimonial: "Like you were looking at my speakers. Thank you!!!"
Volume barely audible with control high. is this perhaps a pre amp problem? Earphone output works fine.
No the pre-amp just gives you enough volume to hear it, the main amp takes it higher. However since the sound is normal on earphones. Then it is the headphone connection that is faulty. The socket side, not the headphones themselves. When headphones are placed in a unit, the plug breaks the contact with the internal or external speakers. But when it's removed it should restore the sound to the speakers. But your unit is not doing that, so there is a bad connection on the socket.
Sep 25, 2018 | Audio Players & Recorders
My ipod plays songs and i can hear the music but when i switch to radio there is no sound speakers do not work on radio..what is wrong????
Hi Fay
You need to clarify what you are saying....
Your iPod plays songs and you can hear music?
Where is sound coming from... Earphones?
How do you switch iPod to Radio....
Is there a cord connecting both together?
I would then suspect cord or connector type not matching up with radio input connector.
Connectors can be Sterio or Mono
Look at spacing on connector....
Earphone Adapter may help here
Mar 03, 2015 | Audio Players & Recorders
No sound but reading discs
Every one enjoys listening to music . When CD player stops doing its job we take it to a repair shop. But before doing that we can try out few simple ways to troubleshooting CD player which may save us from paying huge amount for repair.
Troubleshooting involving diagnosis and then fixing it by finding the cause for the problem. First step involves focusing on a specific problematic area . Next step would be to check if the connections are proper and the last step is to troubleshoot. Let us look at each step in detail..
You can start by checking the earphone port,By using an earphone jack,inserting into the earphone port...If no sound comes out from it, that means it's not from the speaker, but from the board of the radio.The sound IC has is damaged and will need to be replaced..
To fix these,you might need to contact a repair man.
But, if sound comes out from the earphone jack, That means it's a minor case,it will be a problem from the speaker of the Mini Disc Player.
Checking the speaker connection..You might need to open up the speaker
Test the speaker by using a AA battery with small wires on the positive and negative side of the speaker. If sound comes out,that means i wire has cut or remove from somewhere inside the speaker, But if still no sound coming out,That means will go back to IC on the bard of the radio..
Keep me posted when your done checking..
Thanks for using fixya
Aug 07, 2011 | Sony MDS-JE330 Mini Disc Player
Can i listen to fm radio without using earphones?
It will be depends on your mobile brand....
Jun 30, 2011 | Cell Phones
Just purchased ASUS Essentio Desktop PC - model CM1630. Salesperson gave me the impression there are built in speakers, but I have yet been able to hear sound. HELP, please!
Base on the specification of the Asus Essentio CM1630, it doesn't have a built-in speaker for multimedia listening.
Mostly, built-in speakers that came with the computer are only for knowing the beep codes of your motherboard. To know if is it starting up or there are errors on your computer.
I would suggest getting a pair of speaker to easily resolve this issue.
You can also try to connect an earphone or headset to try if there is any problem with the sound card of your computer. Just connect any earphone or headset that you might have and see if you can hear any sound.
Feb 17, 2011 | ASUS Essentio Desktop with Intel Pentium...
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
Very low volume
Have done more research on this, and made some tests. I found the Ext Speaker jack sometimes did not make good contact when the earphone plug was removed, and cleaned/lubed the jack ... the entire unit must be disassembled for this, as the jack is mounted on the third circuit board which is soldered to the antenna jack and a ground shield in several places.
Audio output to an external speaker, whether connected to the earphone jack or directly to the main speaker contacts, is the same. An unpowered external speaker (4-inch audio speaker was used) has quite satisfactory volume. The internal speaker audio works, but seems distorted - I'll try to find a replacement.
Sep 16, 2008 | Icom IC-R10 Handheld Scanner
May 26, 2008 | Harley Davidson 426290 AM/FM Radio
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Sound cuts out when I connect earphones
It is not unusual for this to happen in a regular T.V. set as this is a product of it's design. The solution is to short the internal mech, however this may lead to damages to the audio output of the set. Consult with the service manual first.
Oct 17, 2007 | Samsung TSL2793HF 27" TV
32 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
