Question about Dual Audio Players & Recorders
Dual internet radio,Outlet of earphone damaged, hence no loudspeaker sound ,
Lund on earphone still active but not on main speaker
Posted by Peter herrmann on
5 Related Answers
Anonymous
SOURCE: Ear phone speaker not working
I have the same problem. Seems like this is a common problem - my phone is quite new and is covered by warranty. I have given it to the service center - will post the solution of what they did to fix it.
Posted on Mar 16, 2008
Anonymous
  • 92 Answers
SOURCE: LG TU 550 (australian model)
you have to buy bluetooth headset
and then connect to your mobile
for more information
you can mail me
[email protected]
thanks
Posted on Apr 03, 2008
Anonymous
  • 62 Answers
SOURCE: itouch loudspeaker, earphones?
No just the models with that feature have the loudspeaker. my girlfriends sisters ipod touch doesnt have it either. I hope that helps you out.
Posted on Dec 31, 2008
Anonymous
SOURCE: no sound from speakers or earphones
hi dear
may be problem is that sound driver is not install in your laptop pc so plz install sound driver properly then your problem is solve.
thanks
amit
Posted on Apr 28, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Mains Hum on Ferguson FRG-R121D
Do you have a home theater line conditioning surge protector connected to this unit? like Monster or Panamax? What's probably happened is either a voltage spike or brownout has blown a resistor or diode in the unit, Or, Another circuit in your home has a loose connection and is creating a ground loop. It could be as simple as a light bulb getting ready to blow. It can be caused by just about any device in the house that "seems" to be working fine, yet it affects your receiver. No kidding. If your receiver has a three prong AC plug, you can go to Lowes or Home depot and get a two prong adapter for about a dollar, plug that in, if the noise dissapears, you know it's a ground loop. Also, check all your interconnect cables between sources like CD/DVD/etc. If they are the cheap cables that came with the products, throw them away! they are worthless and you may as well be listening to AM radio!. Good interconnects are actually more important than expensive electronics!. If you have ever gone to Wendy's and had a Frosty, try and **** it thru a straw, it doesn't work and your equipment is starving, let alone the cheap cables are notorious for noise and have NO ground shield to speak of. If you have good cables, awesome! make sure the ends are tight, analog rca ends have a way of loosening over time as well from expansion and contraction. Pull each one off and lightly twist the gold ends tight. I hope I haven't put you on overload! I have a tendancy of doing that, I'm just a perfectionist at this stuff. If you try all this and still have noise, post a comment and there are a few other things we can try before "off to the service shop" Hope this helps.
Posted on Jun 24, 2009
How do I connects my lg phone to the loudspeaker
If you mean to the internal speaker, there should be a speaker symbol when making or receiving a call, which you press to activate.
If external loudspeaker, you can patch your earphone out socket to the line-in of your hi-fi / amplifier.
Do not connect an external loudspeaker directly to the phone - this will damage the phone.
If your amp /speaker / soundbar has bluetooth / Wi-Fi capable of pairing with your phone, then switch on both devices and pair them.
May 10, 2018 | LG Cell Phones
Radio no sound
Is there not a loose loudspeaker wire or disconnect the speakers from the radio and check the speakers with a AA battery if okay when connected it should make a clicking noise if okay if the speakers are high power the click from them will be soft but even portable radio speaker will not get damaged with this test if you are scared of damaging it This is a standard test for checking loudspeakers
Mar 13, 2014 | Ford Car Audio & Video
My Acer X960 phone makes screeching sound when I receive a lot, hence I cannot hear the opposite party.
Sounds like your speaker has gone, when you next get a call put it on loudspeaker, it should solve the problem, as its a different speaker, you can put it in loudspeaker from options menu when you get a call.
Jul 10, 2012 | Acer X960 Black Quad Band With 3g Hsdpa...
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Can i listen to fm radio without using earphones?
It will be depends on your mobile brand....
Jun 30, 2011 | Cell Phones
My 6133 is barely audible on headset speaker. Works fine on loudspeaker.
hi there!
there's a huge chance that the headset that you have is already damaged. either its speakers or its cord. try using other headset, if the problem is the same, it can be the headset port (where you insert the headset jack). try moving it while its plugged see if the sound changes. if its the headset, replace it, if its not, bring the phone to a local technician so that they can replace the earphone slot. =)
Apr 09, 2011 | Nokia Cell Phones
Sony icf7600 when earphones are plugged in the loudspeaker ceases but no sound in earphones
try replacing the female socket of the ear phone.... may be the metal leads there are oxidised due to moisture.
srinivasan k.b.
Nov 05, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Itouch loudspeaker, earphones?
Dec 31, 2008 | Apple iPod touch
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
