Question about Mercury Outboards - Zinc Merc Outdrive
1995 Procraft with Mercury Quicksilver Remote, will not move throttle unless red lever is engaged to shift into gear. Works fine in either fwd or rev.
Posted by Steve Reeves on
5 Related Answers
Anonymous
  • 318 Answers
SOURCE: 1995 grand cherokee trans not shifting in to second gear
Check transmission fluid levels,,replace lost fluid as needed,,,if this does not work,,take the car to a mechanic,,,sorry to say,,this kind of problem almost alway's requires a transmission mechanic to repair.
Posted on Jan 16, 2009
chuck943
Chuck Martin
  • 783 Answers
SOURCE: My 2003 Mercury Mountaineer Gear Shift is stuck.
See if u have brake lights. This is what energizes the shifter solenoid. There are 2 fuses u can check both are in the under dash fuse panel. Fuse 23 (15amp) and fuse 26 (7.5amp).
To get it out of park turn igntion switch on stopping just short of engerizing the electronics then u should be able to get it out of park and into neutral.
Posted on Feb 01, 2009
Anonymous
  • 112 Answers
SOURCE: driving home car suddenly reving not moving
Sounds like you might have lost the tranny,or at least the shift solinoids inside the tranny.
Posted on Mar 31, 2009
Anonymous
SOURCE: 1995 cadilac deville has problem shifting from 1 to 2 gear
You don't have torque converter shudder. You don't even mention that in your original post! You def had a solenoid issue. My 94 STS did the same thing. I only had reverse, 1st and 2nd gear. Wouldn't shift outa 2nd period. It was a $200 solenoid repair. Car had a 160K on it when that happened. I have almost 170k on it now. Shifts and works fine. you don't need the tranny replaces ad josavv63 indicates.
Posted on Apr 26, 2009
Anonymous
  • 1305 Answers
SOURCE: 1999 F350 crew cab 4x4 ford, gear shift lever
Ok ready to stand on your head under the dash?
It's doable... there is a flange connected to the gearshift lever under the steering column. If you remove the lower dash cover where the fuses are, you should be able to see it when you move the gear shift lever... look around on the floor of the truck to see if you dropped a star-headed bolt or two... these bolts worked loose on my superduty and made shifting very difficult..it was an easy fix... let me know how you do on it.
Posted on May 10, 2009
Mercury 150 hp 2 stroke 2003 everything runs fine with idle throttle lever engaged but when you put motor into gear i stalls idle to slow how do you adjust it thanks
If someone changed props this can cause this problem. You need to be careful that any adjustment is made for throttle rod and not for carbs if not an injected engine. You do not want to fool around with air mixture. Some throttle cables use threaded linkage and length of rod is adjustment for rpm. Others use a stop screw or hex head to move the throttle lever away from the housings.
Apr 01, 2017 | Mercury Cars & Trucks
Rascal scooter
Could be the Throttle Pot or Speed Pot. The levers will change the resistance of the throttle pot. The speed pot feeds the throttle pot.
Move the speed pot while pushing the lever forward. If it works could be the speed pot has a dead spot on it. Also check wires loose and a mechanical issue with the throttle pot and the springs.
Apr 04, 2014 | Health & Beauty
1995 celica 2.2L doesn't engage gear 2,4,r
are you saying this car is a A/T car, AUTO and not a stick?
say so, as both have 2,4 and reverse gears.
i think its a 5speed manual.
so the tip of the shifter is bad, remove it see plastic parts bad.
you could shift car , by moving the transmission levers and id bet it does work so that leaves. bad shift lever parts.
i bet the lever is real loose , so loose the H pattern is garbage
right> ?
Feb 01, 2014 | 1995 Toyota Celica
Mercury 60 Big Foot outboard
you can adjust the throttle position better than what you have described
the first forward action is the gear engagement and the at least 1/2 " lever movement before the engine starts to rev up
the same for reverse
that gives more control over the required rpms
Jun 02, 2017 | Boating
Evinrude 65hp 65853B Shift lever stuck
Yes, it will be corroded. Just have to find where.
Look to remove the cable from the link arm in the motor.
Can you now set the throttle lever in fwd and rev? Does the cable moves? If Yes, it's in your engine that you have trouble. If no, disconnect cable at the throttle lever and re-check...
If it's the engine: Remove the gearhousing. If now you have movement, the gear housing is stuck ( water inside that has corroded everything, good luck)
If still no movement, check the linkage, you'll have to remove the engine block from the exhaust plate.
The best is to find a service manual to get the right way to disassemble and reassemble...
Oct 13, 2017 | Boating
Just bought boat & prop will not in gage all the time
put your motor on the garden hose after you remove the propeller (you don't want to step into a spinning blade). remove the cover and start the motor.
Have some one shift the motor (without engaging the throttle).. This will show you which cable is the shift cable.Disconnect the shifter, and while it's running, shift it full forward and full reverse to fin the halfway point. Next return the control box to neutral and adjust the connector. Start it up and see if the control box will shift the gear box as far as you did by hand. If not you need to take the control box apart and move the cable anchor so you get more movement. Get a repair book and take pictures as the guts of a control box can be VERY confusing.
Sep 06, 2012 | Quicksilver Mercury/Quicksilver Parts...
My mercury tillr 9.8 shifts backwards with throttle controller
Hi, basically it depends on the control box you have. On some you can fit the shift cable in 2 different positions, each one alters whether the cable pushes or pulls when you shift the gear lever. On others it cant be changed(not common). Regards Phil.
Sep 03, 2012 | Boating
1971 MERCURY OUTBOARD ENGINE REVS WHEN PUT IN REVERSE
is that on the remote control lever ? if yes then adjust the throttle cable to push against the throttle stop on the engine end so when you select gears it only moves when you go to accelerate ! mite need to adjust the carb pickup to align with mark on main lever that moves the timing rod to the trigger under the flywheel !
Sep 30, 2011 | Light Outboard Motor Boat Bass Fishing...
1990 mercury 150 outboard motor
sound like the throttle control (lever) is at fault not engaging the throttle in FWD position, but ok when in neutral, check the release button insure it pops out to lock the throttle...hope this helps...GL
Jul 06, 2009 | Boating
Mercury Outboards - Zinc Merc Outdrive Logo
47 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
