Question about Kohler Electrical Supplies
AC sensing lost kohler 12resv generator
It worked fine wired as is for 250 hrs. It powered fine this morning then poof! AC sensing loss. Electrician coming later. We'll chk the transfer switch. In Dominica so no utility power yet.
Posted by Robert Beyer on
5 Related Answers
Anonymous
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
Anonymous
SOURCE: When utility power goes out, the transfer switch doesn't transfer
Call an electrician.
Posted on Jan 23, 2010
Fred Yearian
  • 5603 Answers
SOURCE: I have a Generac 15KW generator, the starter went
I suspect you will SOMEPLACE find protection fuse(s) for the sense lines from the utility. That is the first place to check.
Posted on Mar 24, 2010
Anonymous
  • 760 Answers
SOURCE: I bought a Generac 17kw with automatic transfer
If you are using a Manual transfer switch, then you should manually operate the system. Why don't you use the switch it came with? Why would you use a 200a manual transfer switch on a 17kw generator? The idea is to move your critical circuits into the transfer switch panel. Then it would operate in auto.
Posted on Jul 03, 2010
ecoenergy08
  • 20 Answers
SOURCE: I have a Briggs & Stratton Automatic Home
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
Posted on Feb 15, 2011
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
First start up
Try disconencting the remote start wires between the transfer switch and the generator, if ot still does it you have a bad control board. If it stops, then check the transfer switch for correct wiring of utility and generator power wires, also check with an ohm meter if the run contacts in the transfer switch are closed, that would indicate loss of sensing, or bad board
Jul 19, 2013 | Kohler Electrical Supplies
1995 pontiac lt1 sluggish no power slight back fire
sounds like a fuel problem, may have water in the gas or needs a fuel filter , try a bottle of drygas before the filter
Jan 04, 2013 | 1995 Pontiac Firebird
I have a Briggs & Stratton Automatic Home Generator 7 kW, Model# 40301. I had it installed by an electrician. Who also installed Briggs & Stratton Transfer Switch 50 Amp. The problem is the...
Feb 15, 2011 | Briggs Stratton 7,000 Watt Automatic Home...
Generac 10 k battery charger installation at the generator, where does the ac input wires connect
Your electrician should have run a set of wires out to the generator from the transfer switch. The unit actually comes with a fuse holder, fuse, terminal connector, and jumper wire for installing these wires to the t1 or t2 terminals in the transfer switch. The dc wires will be the ones coming out of the battery charger, 1 of them will have a red marker around it, that is your dc positive. The 2 wires coming out of the opposite side of the battery charger is actuall your ac connection.
hope this helps let me know.
Nov 01, 2009 | Guardian Electrical Supplies
Wipers won't come on. just all the sudden stopped working.
I think there is a GEM module that controls this, although the motor and fuses need to be verified good.
Oct 02, 2009 | 1998 Ford F150 Regular Cab
Shuddering and white smoke on acceleration
yes it is most likely the turbo oil seal is leaking.
May 03, 2009 | Ford F-250 Super Duty Cars & Trucks
Electrical Supplies Logo
883 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
