Question about Locks & Locksmithing
I have onity ht24 lock, my lock was not reading card(not master as well), then i open it with machine. then its start reading card. i am having such problem in every 2 or 3 days
Posted by mayur amrutiya on
2 Related Answers
wcilocktek
Ken Croston
  • 7 Answers
SOURCE: Onity lock ht24--In the test
Chris, The HT 24 Lock does not have a keyboard so this test is not relevant to your lock. This test feature is for an Onity lock with a numbered keypad.
Hope this helps. If you have any more problems or questions you can call me or send an email through my web site.
Ken Croston 407 814 4974
www.ElectronicLocksmith.com
Posted on Nov 04, 2010
Anonymous
SOURCE: My onity lock is dead,
If it will not take any programming from the box, you may have a broken wire inside the lock.
Posted on Dec 30, 2010
Onuity HT24.Lock needs updated and master wont work.Using PP the PP I attempted to perform update but the the lock doesn't recognize the PP is connected. Upon inspection I find that ground is broken where...
I suggest you try one of those instant download manuals. My nephew bought one for me
when my car broke and we could fix it all by ourselves with the manual at www.reliable-store.com . This website is very good for this.
?Try it.
Mar 11, 2018 | Cars & Trucks
I hear click , but can not lock the door
Need more information. Try lifting up on the handle when you card the lock. A worn or broken clutch assembly is a common issue with older TESA/Onity HT24 locks.
Mar 09, 2015 | Locks & Locksmithing
Why does my onity ht24 lock not open when the handle is pushed down? it always works when the handle is lifted up but almost never when the handle is pushed down.
The lever return spring might be weak or broken. Lift the lever slightly and then push down. If it opens, that's the problem. If it still won't open, something else might be broken or badly worn. The handle is pushed down far more often than it's pulled up.
Apr 29, 2014 | Locks & Locksmithing
Qnity ht24
Sounds like the battery board needs replaced. If a solder point is bad, it can loose time or programming when the door slams. Sometimes it is due to corrosion from being on an exterior property. Feel free to call if you have any other questions or need the board.
407-814-4974
Feb 17, 2014 | Locks & Locksmithing
I have 5 brand new TESA Onity locks that will not work after I program the lock.Just blinks red when I insert the key in it.
This page is for Onity's Supplies and Services:
http://www.onity.com/support/supplies-and-services/
It is the only source of contact information that I could find toward solving your problem.
I suggest that you contact them through the phone number listed on this page. For your convenience,
By Phone: 1-800-749-2983
By Email: [email protected]
Jul 27, 2011 | Locks & Locksmithing
I have a Onity Advance lock and the green light is flashing at a very rapid rate. The lock stays in the open position all the time and never goes to the secured position. So you can just press the handle...
I am going to guess that this lock is a common door.
The flashing green and staying unlocked indicates that this lock is in "Office Mode"
If a master key has office mode capability, and the lock program has office mode capability, the lock can be permantly unlocked by "double dipping the key". It can be put back in to regular mode by "double dipping the key" again. This will only work if the master has the "office mode" capability.
Thanks,
Ken Croston
407 814 4974
Jul 13, 2011 | Locks & Locksmithing
Onity lock ht24--In the test mode, what does "FF" mean when keyboard test is run?
Nov 03, 2010 | Locks & Locksmithing
Locks & Locksmithing Logo
870 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
